Scenario A
Tried to allocate swap memory of 6GB through the script:
As per the “swap_area_modified_killed.png” snap, the process gets killed after using 1915MB RAM area out of 1972MB total RAM and 2017MB of SWAP area from 7144MB(Total ~4GB from ~9GB)
UNKNOWN: Retargeting InceptionResnetV1/Repeat_2/block8_5/Branch_1/Conv2d_0c_3x1/Relu to InceptionResnetV1/Repeat_2/block8_5/concat
UNKNOWN: Eliminating concatenation InceptionResnetV1/Block8/concat
UNKNOWN: Generating copy for InceptionResnetV1/Block8/Branch_1/Conv2d_0a_1x1/convolution + InceptionResnetV1/Block8/Branch_1/Conv2d_0a_1x1/Relu || InceptionResnetV1/Block8/Branch_0/Conv2d_1x1/convolution + InceptionResnetV1/Block8/Branch_0/Conv2d_1x1/Relu to InceptionResnetV1/Block8/concat
UNKNOWN: Retargeting InceptionResnetV1/Block8/Branch_1/Conv2d_0c_3x1/Relu to InceptionResnetV1/Block8/concat
UNKNOWN: After concat removal: 137 layers
UNKNOWN: Graph construction and optimization completed in 1.2832 seconds.
Killed
nano@nano-desktop:~$ swapon -s
Filename Type Size Used Priority
/mnt/swapfile file 6291452 0 -1
/dev/zram0 partition 255996 0 5
/dev/zram1 partition 255996 0 5
/dev/zram2 partition 255996 0 5
/dev/zram3 partition 255996 0 5
Scenario B
Tried to allocate swap area 1GB to each CPU ZRAM:
[zram_modified_killed|690x387]
(https://forums.developer.nvidia.com/uploads/short-url/pv2TwAN8xu1FMGFMN4ch6uPNQIK.jpeg)
As per the “zram_modified_killed.png” snap, the process gets killed after using 1915MB RAM area out of 1972MB total RAM and 2017MB of SWAP area from 7144MB(Total ~4GB from ~9GB)
$ sudo tegrastats
RAM 1904/1972MB (lfb 1x1MB) SWAP 2030/40000MB (cached 0MB) IRAM 0/252kB(lfb 252kB)
/dev/zram0 partition 1023996 7056 5
/dev/zram1 partition 1023996 7052 5
/dev/zram2 partition 1023996 7068 5
/dev/zram3 partition 1023996 7064 5
In the both the scenarios, the process got killed after using ~4GB(2GB swap & 2GB RAM) even the swap area is still not fully occupied.
