Removing obsolete PGI Fortran compilers
I need to do a little cleanup on the drive containing my PGI compiler. I’ve got versions 10.x and 2010. What’s the safest way to accomplish this?
I’m using the linux86-64 version.
Can I just do an rm on the directories within the linux86 and linux86-64 directories like this:
rm -r 10.*
rm -r 2010
BTW, unpacking the 11.6 tar file gave this:
tar xpfz pgilinux-116.tar.gz
gzip: stdin: unexpected end of file
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
Looks like a problem. Is it?
Tom
Hi Tom,
Yes, you can simply use rm to remove old releases.
I suspect your package is corrupt. What’s the MD5sum? It should be: 24f4f448ea1c091e18a94b140e8d660f
  • Mat
Checksum didn’t check out. Downloaded it again, and the install worked.
