I’m currently trying to render frames with Blender using OptiX inside of Docker. The host machine is a g4dn.xlarge EC2 instance, with a Nvidia T4 GPU attached and nvidia driver/nvidia-docker2 installed. When forcing the use of OptiX on the host machine, the rendering script works properly. However, if I try to run the same script inside of an Ubuntu Docker image, I get the following error:
OPTIX_ERROR_UNKNOWN in optixDeviceContextCreate(cuContext, &options, &context) (device_optix.cpp:235)
Please find here the Dockerfile I’m using to build the image.
I found this issue that seems to be somehow related and states that some files need to be mounted into the container:
- libnvoptix.so.X
- libnvidia-rtcore.so.X
When not mounting them, the OptiX device query does not work at all. When mounting them, the device query works but the rendering fails with the aforementioned error.
Also please find below the output of the nvidia-smi
command on the host machine:
| NVIDIA-SMI 450.51.06 Driver Version: 450.51.06 CUDA Version: 11.0 |
| | | MIG M. |
| 0 Tesla T4 Off | 00000000:00:1E.0 Off | 0 |
| N/A 24C P8 9W / 70W | 0MiB / 15109MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Do you folks have any hints ?
Thanks a lot in advance
