Reordering a vector. kernel working only for single precision
I have a program, which basically amounts to rearranging an array of size num_elements.
The code below works fine for single precision, but gets the wrong values sometimes with double precision.
card: Tesla M1060
cuda 4.0
#include <stdlib.h>
#include <stdio.h>
__global__ void rearrange(float *dst, float *src,
                          int *map, const size_t n)
  // compute the global element index this thread should process
  unsigned int i = threadIdx.x + blockDim.x * blockIdx.x;
// avoid accessing out of bounds elements
  if(i < n) {
    dst[i] = src[map[i]];
int main(void)
  const int num_elements = 19*23520;
// compute the size of the arrays in bytes
  const int num_bytes = num_elements * sizeof(float);
  const int num_bytes_d = num_elements * sizeof(int);
int *device_map    = 0;
  float *device_dst = 0;
  float *device_src = 0;
int *host_map    = 0;
  float *host_dst = 0;
  float *host_src = 0;
  float *host_out = 0;
// malloc the host arrays
  host_dst = (float*)malloc(num_bytes);
  host_src = (float*)malloc(num_bytes);
  host_out = (float*)malloc(num_bytes);
  host_map = (int*)malloc(num_bytes_d);
// cudaMalloc the device arrays
  cudaMalloc((void**)&device_dst, num_bytes);
  cudaMalloc((void**)&device_src, num_bytes);
  cudaMalloc((void**)&device_map, num_bytes_d);
// if any memory allocation failed, report an error message
  if(host_dst == 0 || host_src == 0 || host_out == 0 || host_map == 0 ||
     device_dst == 0 || device_src == 0 || device_map == 0) {
        printf("couldn't allocate memory\n");
        return 1;
// define a mapping which reverses the order
  for(int i = 0, j = num_elements-1; i < num_elements; ++i, --j) {
        host_map[i] = j;
        host_src[i] = i;
cudaMemcpy(device_src, host_src, num_bytes, cudaMemcpyHostToDevice);
  cudaMemcpy(device_map, host_map, num_bytes_d, cudaMemcpyHostToDevice);
const size_t block_size = 128;
  size_t grid_size = num_elements / block_size;
// deal with a possible partial final block
  if(num_elements % block_size)
      ++grid_size;
// launch the kernel
  rearrange<<<grid_size, block_size>>>(device_dst, device_src, device_map, num_elements);
// copy the result back to the host memory space
  cudaMemcpy(host_out, device_dst, num_bytes, cudaMemcpyDeviceToHost);
// check result
  for(int i = 0; i < num_elements; ++i) {
      if( host_out[i] != host_src[host_map[i]] ) {
          fprintf(stderr, "%g vs %g\n", host_out[i], host_src[host_map[i]]);
          return 1;
  // deallocate memory
  free(host_map);
  free(host_dst);
  free(host_src);
  free(host_out);
cudaFree(device_map);
  cudaFree(device_dst);
  cudaFree(device_src);
