Replace a customize kernel driver
Followed Jetson developer guide to change customize kernel driver on L4T r35.2.1.
However, the kernel driver did not be changed as the kernel_supplements.tbz2 has been zip with new kernel driver. After ran apply_binaries.sh, the customize kernel driver of /lib/modules was revised back to released driver.
Is it normal?
If not, would you advice a proper way to replace a customize kernel driver?
https://docs.nvidia.com/jetson/archives/r35.2.1/DeveloperGuide/text/SD/Kernel/KernelCustomization.html
  1. Replace Linux_for_Tegra/kernel/Image with a copy of this file:
    $kernel_out/arch/arm64/boot/Image
    Optionally, archive the installed kernel modules:
    $ cd <modules_install_path>
    $ tar --owner root --group root -cjf kernel_supplements.tbz2 lib/modules
    You can use the installed modules to provide the contents of /lib/modules/<kernel_version>/ on the target system. Before you run apply_binaries.sh, make a copy of this archive to replace the one at this location on the target device:
    Linux_for_Tegra/kernel/kernel_supplements.tbz2
Thank you,
The optional steps are not required. If you download the system image through SDKManager, it will be in
nvidia/nvidia_sdk/JetPack_5.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/
And you can execute step 5 6 7 to replace with self-built kernel binaries/device tree and then flash the system. It is not required to execute apply_binaries.sh
I have a question related to this.
Can you elaborate @DaneLLL why in this case apply_binaries.sh is not required but here (Extlinux.conf is not found, the problem with PCi Endpoint Mode Testing - #2 by WayneWWW) is mandatory to avoid “/boot/extlinux/extlinux.conf is not found” issue?
Hi DaneLLL,
Thank you for your reply.
We know that modify dtb only doesn’t need to run apply_binaries.sh
However, if we need to use a customize camera driver, do we need to modify kernel_supplements.tbz2? need to run apply_binaries.sh ?
Or just manaully copy new customize camera driver to roofts.
Thank you,
Hi @HuiW
I have a custom nv_imx219.ko in my system and I faced the same problem with apply_binaries.sh. That overwrites every fix you did to your custom modules.
I usually flash the system after apply_binaries.sh and I then upload the modified module ko from the local sources folder (e.g. Linux_for_Tegra/sources/kernel/kernel-5.10/drivers/media/i2c/nv_imx219.ko that is not overwrited) to the Jetson’s /usr/lib/modules/5.10.104-tegra/kernel/drivers/media/i2c/.
@DaneLLL please, let us know if this is the correct (and only) way to use custom modules.
This looks possible. We have enabled Raspberry Pi v2 camera in default release and nv_imx219.ko is included. If you have customization to the file, it is possible to be overwritten. So you would need to manually overwrite it back to the customized one.
