Replace the problem of using gpu-id
I have implemented the rtsp stream example with reference to here:deepstream_python_apps/apps/deepstream-rtsp-in-rtsp-out at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
When I replaced the gpu-id of pgie, I found that the gpu-id of the plugins like nvstreammux, tiler, nvvidconv, etc. must also be replaced. As shown below, why is this? How can I determine which plugin’s gpu-id needs to be replaced together?
屏幕截图 2022-07-28 153116
If you only replace the gpu-id of pgie, do not replace the gpu-id of other plugins. The output rtsp stream will be like this:
Hi @2016674027 , Your diffrent GPUs may have diffrent memory processing. You can try to set the nvbuf-memory-type to Unified.
• DeepStream Version
• TensorRT Version
