I am working on a 1/10th scale autonomous vehicle, and I am using the Jetson to compute real-time actions for an autonomous agent I trained. When the Jetson was powered with a 12V battery, I gave the car a manual full throttle command, and I immediately noticed the Jetson began smoking and shut down. When looking at the carrier board, I noticed a light burn mark on an IC in the bottom corner (across from the 12V barrel jack), which leads me to believe I burned it out with excess current. I was thinking of trying to replace the burned out IC, but I don’t even have a way to identify which IC it is. Does anyone have repair suggestions? Or, alternatively, is there an easy way to replace the carrier board?
Thank you!
Please refer to Jetson Orin Nano Developer Kit Carrier Board Reference Design Files
https://developer.nvidia.com/downloads/assets/embedded/secure/jetson/orin_nano/docs/jetson_orin_nano_devkit_carrier_board_reference_design_files_a04_20230320.zip/
