Replicator on_frame function not working properly
The function omni.replicator.core.trigger.on_frame is not working properly.
Calling the function omni.replicator.core.trigger.on_frame(num_frames=100, interval=10) or omni.replicator.core.trigger.on_frame(num_frames=1000, interval=1) leads to the same result but this is not expected. In fact I always end up with 1000 rendered samples and these samples rendered with the two methods are identical.
The documentation says:
  • interval – The generation frame interval to execute on.
  • num_frames – The total number of frames to execute on.
Therefore if I call the function with the parameters num_frames=100 and interval=10 I expect to render 100 samples, one each 10 time interval, and if I call the function with the parameters num_frames=1000 and interval=1 I expect to render 1000 samples, one each 1 time interval.
Hi @federico.domeniconi. I’ve moved this over to the SDG forum where they’ll be able to better help you out with this.
What is the SDG forum?
Synthetic Data Generation aka Replicator Forum
Sorry the documentation for trigger.on_frame is not clear.
Without a custom Writer, Replicator will always write an image for every frame. What trigger.on_frame does is control when randomizations happen.
For example:
spheres = rep.create.sphere(semantics=[("class", "sphere")], position=(0, 0, 100), count=6)
with rep.trigger.on_frame(num_frames=10,interval=5):
    with spheres:
        rep.modify.pose(
                position=rep.distribution.uniform((-300, 0, -300), (300, 0, 300)),
                scale=rep.distribution.uniform(0.1, 2),
Will generate 50 frames total (10*5) and randomize the position and scale of the spheres every 5th frame.
I can combine this with a separate trigger that performs another randomization
    with rep.trigger.on_frame(num_frames=50):
        with spheres:
            rep.randomizer.color(colors=rep.distribution.normal((0.1, 0.1, 0.1), (1.0, 1.0, 1.0)))
Which will randomize the color of my spheres every frame.
With the two above, I will produce 50 frames, every frame the spheres will change colors, and every 5th frame they will change position and scale.
with rep.new_layer():
    camera = rep.create.camera(position=(0, 500, 1000), look_at=(0, 0, 0))
    # Create simple shapes to manipulate
    plane = rep.create.plane(semantics=[("class", "plane")], position=(0, -100, 0), scale=(100, 1, 100))
        with spheres:
            rep.modify.pose(
        with spheres:
render_product = rep.create.render_product(camera, (512, 512))
writer = rep.WriterRegistry.get("BasicWriter")
writer.initialize(
    output_dir="trigger_intervals",
    rgb=True,
writer.attach([render_product])
We will try to update the documentation ASAP as well as providing examples, and will try to make the API parameters more clear in a future update.
You might also want to look at trigger.on_time to see if it works for your use-case.
Thank you for the explanation.
At this point I have another question: is there a way to render a sample every N frames? I don’t need to randomize anything since I’m running a physics simulation while rendering.
The “easiest” way to do something like this right now would be to write a custom writer ( you can sub-class BasicWriter or another writer) and have it skip writing certain frames to disk.
They’ll currently still be rendered by the renderer, but won’t be written to disk.
Longer-term, this is a feature that has been requested from multiple sources and we are looking into ways of working with the physics system to introduce callbacks or other methods of conditionally triggering renders.
I have no idea how to write a custom writer for setting write one frame every 10 seconds.
Can you provide the Sample code for me? Thank you!
I think you can do this by using rep.trigger.on_time() instead of rep.trigger.on_frame().
https://docs.omniverse.nvidia.com/py/replicator/1.9.8/source/extensions/omni.replicator.core/docs/API.html#omni.replicator.core.trigger.on_time
@dennis.lynch I tried your example (changed the numbers a bit):
    camera = rep.create.camera(position=(0, 0, 10), look_at=(0, 0, 0))
    spheres = rep.create.sphere(semantics=[("class", "sphere")], position=(0, 0, 0), count=1)
        with spheres:
            rep.modify.pose(
                position=rep.distribution.uniform((-2, 0, -3), (2, 0, 3))
        with spheres:
writer.initialize(
    output_dir="C:\\Users\\dsiss\\Downloads\\output",
    rgb=True,
and as a result, the sphere’s position and color are remdomized every five frames (as if both randomizations have the same trigger).
you can see the output here: output - Google Drive
Thank you
I have a new example too that works with physics. In this example I use an on_time trigger for physics and randomization, and an on_frame trigger to render an image every X-number of frames.
Snippet:
    with rep.trigger.on_time(max_execs = 5, interval=2):
        rep.randomizer.create_props()
    manual_trigger = rep.trigger.on_frame(max_execs=5, interval=60)
writer.attach(render_products=[render_product], trigger=manual_trigger)
The simulation by default plays at 30fps, so with an interval of 60 on the on_frame triggers at the end of the 2 second simulation
My simulation drops fruit from above the box, but only captures an image at the end.
