Request for NVIDIA NIM API Rate Limit Increase (40 → 200 RPM)
Hello NVIDIA Support Team,
I am writing to kindly request a rate limit increase for my free NVIDIA NIM API account.
Here are my account details and the reason for my request:
• Account Email: chrisingermania@yahoo.com
• API Key ID (ultimele 4 caractere): nvapi-
• Current Limit: 40 RPM
• Requested Limit: 200 RPM (or the next available tier)
Use Case and Reason for Increase:
I am using the NIM API for personal development and testing, specifically for agentic coding workflows (in tools like Cline/VS Code or OpenClaw).
These tasks involve multi-step reasoning, which can easily generate over 40 API calls per minute.
The current limit frequently causes 429 “Too Many Requests” errors, which completely blocks my workflow and makes the API difficult to use for any realistic development scenario. An increased limit would allow me to properly test and iterate on my personal projects.
I understand this is a free tier and I am using it strictly for personal, non-commercial purposes, with full respect for the service.
Thank you very much for your time and for making these powerful models available for developers.
Best regards,
Antoniou Christos
Hello NVIDIA Team,
I am writing to request a rate limit increase for my NVIDIA NIM API account.
Current limit: 40 RPM
Requested limit: 200 RPM (or the next available tier for individual developers)
Use case: Personal AI development and testing. I use NIM models through various tools for coding assistance and model evaluation. The current 40 RPM limit causes frequent 429 errors, especially when multiple API calls are triggered in a short period (e.g., code generation + validation + retry in a single workflow).
I understand the free tier is intended for testing, but 40 RPM is often insufficient even for basic development workflows. I’m not looking to build a production system — just a reasonable threshold to test real-world usage without constant rate-limit interruptions.
API Key: Will provide via private message if needed
Thank you for considering my request!
Someone?
@staff8
Hey @chrisingermania, I don’t know if this helps, but a moderator previously replied with this to someone asking for the same thing as you:
“Many of you are using free tier API access to NVIDIA NIMs. This usually involves a rate limit that is dependent on model, use-case and the amount of current overall traffic using the same access. There is no official way to circumvent this rate limit or to receive a rate limit increase on that same tier. And specifically here on the forums we do not have any influence on those rate limits. To make full use of a NIM blueprint you will need to deploy it. For more details on NVIDIA NIM refer to…”
You should take a look at that and check it out.
Apparently there is no way and on deepseek v4 pro after 10 minutes it gives me 429 every 10 minutes…I don’t understand the system.
First of all, @chrisingermania, you’re using the free tier, right? So you’re not paying anything, correct? Because I’ll tell you right now, if that’s the case, they are never going to give you that RPM increase. Those RPM increases are meant for people who actually pay and deploy models for AI workloads. It’s just logical. Think about it: if they gave higher RPM limits to everyone on the free tier, nobody would pay. The free tier is exactly that: for testing basic and casual things. If you want higher RPM limits and better service, then you are going to have to pay, no matter what.
Please teach me, if I want to pay, how do I do it, where do I put the card, because I don’t even have a billing section…
First, go to the model you prefer, for example DeepSeek V4 Flash. In that section you’ll see three options: Experience / Model Card / Deploy.
Click on Deploy and you’ll see several options such as Partner Endpoints or Self-hosted Deployments.
From there, you choose the option you want, and it will show you the pricing and deployment costs.
You can start with DeepSeek Flash since it’s the cheapest one, so you can learn how the process works first. And if you need help, you can always contact a moderator privately and ask for guidance. There’s no problem with sending a direct message saying you want to pay and deploy properly.
