Request to resolve IIC debugging issues
Teacher:
When I connect IIC0 and IIC1 together (IIC0. SDA - IIC1SDA, IIC0. SCL - IIC1. SCL). Use the command ‘i2ctest - y - r 7’ ”Searching for the devices connected to IIC1 yielded two results: 0x25 and 0x40. So, which one(0x25 and 0x40) is the address of device (IIC0)?
JetPack: JetPack 5.1.5.
Core board type:orin nano 4gb.
Attached figure:
You should confirm with device vendor for the real slave address.
Teacher:
I connected the IIC0 and IIC1 of the Orin nano 4G development board together, so the address read should be the address of the development board IIC0.
How to find the address of development board IIC0?
You can issue the command before and after connect the device to clarify.
Teacher:
I have tried and the results are as follows:
1.After disconnecting IIC0 and IIC1, the result of running the command is as follows:
2.After connecting IIC0 and IIC1 together, the result of running the command is as follows:
Question:
1.How to use IIC1 to send data and IIC0 to receive data? Achieving mutual debugging effect?
2.I have checked the “device tree” and “pinmux”. Do I need to set IIC0 to SLAVE mode in the device tree?
Teacher, does this indicate that the address of IIC0 is 0x40?Is my understanding correct?
Teacher, can you give me a reply today?
Looks like your devices have two slave i2c devices one is 0x40 and another is 0x25.
Teacher, this is my issue. Please give me some guidance.
I have carefully read your reply, and it is almost irrelevant to my question, even irrelevant. May I ask if you are unable to understand the question? Still can’t understand my language?
May I ask if you can reply to me this afternoon? If you cannot answer, can you forward it to a professional for a response.
Yes, you need set one to slave in device tree.
Have reference to below topic for slave mode.
What did you mean?I didn’t understand. Can you provide more details?
Do you want me to modify the following file?
kernel_tegra234-p3767-0004-p3768-0000-a0.dtb
Get the kernel source code apply the change to build the kernel image and device tree.
Teacher:
The website cannot be opened. After opening it, it looks like the following:
I am update the link in above.
Please try again.
I can now open the website, thank you teacher.
I have been debugging the SPI function these past few days, and I will reply to you once the SPI debugging is completed.
What did you send me? Where can I change the slave mode? Do you know what problem you are solving?
Yes, you would like to config one of the i2c to slave and connect the another i2c control to check the functionality. Now you need reference to the link to build the kernel Image and device tree for it.
Teacher:
I don’t see any steps in your file to change IIC0 to SLAVE mode, right?
If the file ‘dtb - o tegra234-p3768-0000+p3767-0005-nv.dtb’ is changed internally in the system.
Is it okay to set SPI0 to SLAVE mode?
The attachment is as follows:
