Reranking model access URL error
I’m trying to test reranking models with the webpage sampel code, but I have URL errors:
mistral 4B
import requests
invoke_url = "https://ai.api.nvidia.com/v1/retrieval/nvidia/reranking"
headers = {
    "Authorization": "Bearer $API_KEY_REQUIRED_IF_EXECUTING_OUTSIDE_NGC",
    "Accept": "application/json",
payload = {
  "model": "nv-rerank-qa-mistral-4b:1",
  "query": {
    "text": "What is the GPU memory bandwidth of H100 SXM?"
  "passages": [
      "text": "The Hopper GPU is paired with the Grace CPU using NVIDIA's ultra-fast chip-to-chip interconnect, delivering 900GB/s of bandwidth, 7X faster than PCIe Gen5. This innovative design will deliver up to 30X higher aggregate system memory bandwidth to the GPU compared to today's fastest servers and up to 10X higher performance for applications running terabytes of data."
      "text": "A100 provides up to 20X higher performance over the prior generation and can be partitioned into seven GPU instances to dynamically adjust to shifting demands. The A100 80GB debuts the world's fastest memory bandwidth at over 2 terabytes per second (TB/s) to run the largest models and datasets."
      "text": "Accelerated servers with H100 deliver the compute power—along with 3 terabytes per second (TB/s) of memory bandwidth per GPU and scalability with NVLink and NVSwitch™."
# re-use connections
session = requests.Session()
response = session.post(invoke_url, headers=headers, json=payload)
response.raise_for_status()
response_body = response.json()
print(response_body)
ages/requests/models.py", line 1024, in raise_for_status
    raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 400 Client Error: Bad Request for url: https://ai.api.nvidia.com/v1/retrieval/nvidia/reranking
nvidia 4B
import requests
invoke_url = "https://ai.api.nvidia.com/v1/retrieval/nvidia/nv-rerankqa-mistral-4b-v3/reranking"
headers = {
payload = {
  "model": "nvidia/nv-rerankqa-mistral-4b-v3",
  "query": {
  "passages": [
requests.exceptions.HTTPError: 404 Client Error: Not Found for url: https://ai.api.nvidia.com/v1/retrieval/nvidia/nv-rerankqa-mistral-4b-v3
Any help would be appreciated.
Hey @gigit0000,
I’m able to successfully run both of the code snippets you shared!
Can you confirm you’re using the most recent requests library?
Thank you for your reply. I’m running version 2.32.3, which looks the latest. Is there another possibility?
Just to extra clarify - you’re replacing the $API_KEY_REQUIRED_IF_EXECUTING_OUTSIDE_NGC with your API key, correct?
Yes, I double-checked it.
Are you leaving the space between Bearer and the paste API key?
"Authorization": "Bearer nvapi-xxxxxx",
"Authorization": "nvapi-xxxxxx",
Both didn’t work.
Now it works! I retyped the space, and it worked.
Thanks so much for your support!!!
