Process was killed again and can’t get it back to work again.
Here’s the 2 lines in the Yolo train config file
#pretrain_model_path: “EXPERIMENT_DIR/pretrained_resnet18/tlt_pretrained_object_detection_vresnet18/resnet_18.hdf5”
resume_model_path: “USER_EXPERIMENT_DIR/experiment_dir_unpruned/weights/yolov4_resnet18_epoch_050.tlt”
And here’s the Tracecack:
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 209, in
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 205, in main
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 56, in run_experiment
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/utils/spec_loader.py”, line 20, in load_experiment_spec
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 737, in Merge
allow_unknown_field=allow_unknown_field)
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 805, in MergeLines
return parser.MergeLines(lines, message)
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 830, in MergeLines
self._ParseOrMerge(lines, message)
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 852, in _ParseOrMerge
self._MergeField(tokenizer, message)
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 980, in _MergeField
merger(tokenizer, message, field)
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 1054, in _MergeMessageField
self._MergeField(tokenizer, sub_message)
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 1105, in _MergeScalarField
value = tokenizer.ConsumeString()
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 1476, in ConsumeString
the_bytes = self.ConsumeByteString()
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 1491, in ConsumeByteString
the_list = [self._ConsumeSingleByteString()]
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 1510, in _ConsumeSingleByteString
raise self.ParseError(‘Expected string but found: %r’ % (text,))
google.protobuf.text_format.ParseError: 46:20 : ‘resume_model_path: “USER_EXPERIMENT_DIR/experiment_dir_unpruned/weights/yolov4_resnet18_epoch_050.tlt”’: Expected string but found: ‘“’
File “/usr/local/bin/yolo_v4”, line 8, in
sys.exit(main())
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/entrypoint/yolo_v4.py”, line 12, in main
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/entrypoint/entrypoint.py”, line 296, in launch_job
AssertionError: Process run failed.
