Retail Object Detection - Issues Testing
I hope you are well. I am running a SeedStudio reComputer J3011 (Jetson Orin Nano 8GB) with Jetpack 6.2 Flashed. I have Deepstream 7.1 Installed and I am trying to test the retail_detector_100.onnx model, through my RTSP stream.
I have converted it to a TRT file but get a bunch of errors when trying to run deepstream. I am fairly new to this, would you be able to give any advice on this and also check my config files?
I have config_infer_primary.txt:
[property]
gpu-id=0
net-scale-factor=1
offsets=0;0;0
model-color-format=0
model-engine-file=/home/pj/retail-ai/models/retail_model.trt
labelfile-path=/home/pj/retail-ai/recognitionv2_name_list.txt
batch-size=1
gie-unique-id=1
network-input-order=1
infer-dims=3;416;416
maintain-aspect-ratio=1
network-mode=2
num-detected-classes=100
network-type=1
interval=0
output-blob-names=num_detections;detection_boxes;detection_scores;detection_classes
custom-lib-path=/home/pj/retail-ai/repos/deepstream_tao_apps/post_processor/libnvds_infercustomparser_tao.so
[class-attrs-all]
pre-cluster-threshold=0.1
Then I am trying to run from source1_usb_dec_infer_resnet_int8.txt:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
width=640
height=480
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=2
camera-width=640
camera-height=480
camera-fps-n=30
camera-fps-d=1
camera-v4l2-dev-node=0
uri=rtsp://admin:password@10.0.133.219:554/cam/realmonitor?channel=6&subtype=0
[sink0]
enable=0
#Type - 1=FakeSink 2=EglSink/nv3dsink(Jetson only) 3=File 4=RTSPStreaming 5=nvdrmvideosink
type=2
sync=0
conn-id=0
width=0
height=0
plane-id=1
source-id=0
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
codec=1
encoder type 0=Hardware 1=Software
enc-type=0
sync=0
bitrate=2000000
sw-preset
profile=0
output-file=out.mp4
source-id=0
[sink2]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming 5=nvdrmvideosink
type=4
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=4000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
rtsp-port=8554
udp-port=5400
[osd]
enable=1
border-width=2
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
[streammux]
live-source=1
batch-size=1
batched-push-timeout=40000
width=960
height=540
[primary-gie]
enable=1
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
config-file=/home/pj/retail-ai/configs/config_infer_primary.txt
[tests]
file-loop=0
I am getting the following errors:
** INFO: <create_udpsink_bin:646>: Could not create HW encoder. Falling back to SW encoder
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
WARN !! Invalid mode selected, Falling back to GPU
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-7.1/lib/libnvds_nvmultiobjecttracker.so
[NvTrackerParams::getConfigRoot()] !!![WARNING] Can’t open config file (/home/pj/retail-ai/configs/config_tracker.txt). Will go ahead with default values
[NvMultiObjectTracker] Initialized
Setting min object dimensions as 16x16 instead of 1x1 to support VIC compute mode.
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:01.101515930 25600 0xaaaabc35f6f0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/home/pj/retail-ai/models/retail_model.trt
Implicit layer support has been deprecated
INFO: [Implicit Engine Info]: layers num: 0
WARNING: Backend context bufferIdx(0) request dims:1x416x416x3 is out of range, [min: 1x3x224x224, max: 1x3x224x224]
0:00:01.101668572 25600 0xaaaabc35f6f0 WARN nvinfer gstnvinfer.cpp:681:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:2050> [UID = 1]: backend can not support dims:416x416x3
0:00:01.101691420 25600 0xaaaabc35f6f0 WARN nvinfer gstnvinfer.cpp:681:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2201> [UID = 1]: deserialized backend context :/home/pj/retail-ai/models/retail_model.trt failed to match config params, trying rebuild
0:00:01.197310654 25600 0xaaaabc35f6f0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2106> [UID = 1]: Trying to create engine from model files
ERROR: failed to build network since there is no model file matched.
ERROR: failed to build network.
0:00:09.617219218 25600 0xaaaabc35f6f0 ERROR nvinfer gstnvinfer.cpp:678:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2126> [UID = 1]: build engine file failed
0:00:10.001817767 25600 0xaaaabc35f6f0 ERROR nvinfer gstnvinfer.cpp:678:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2213> [UID = 1]: build backend context failed
0:00:10.001895880 25600 0xaaaabc35f6f0 ERROR nvinfer gstnvinfer.cpp:678:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1351> [UID = 1]: generate backend failed, check config file settings
0:00:10.002735603 25600 0xaaaabc35f6f0 WARN nvinfer gstnvinfer.cpp:914:gst_nvinfer_start:<primary_gie> error: Failed to create NvDsInferContext instance
0:00:10.002765107 25600 0xaaaabc35f6f0 WARN nvinfer gstnvinfer.cpp:914:gst_nvinfer_start:<primary_gie> error: Config file path: /home/pj/retail-ai/configs/config_infer_primary.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
** ERROR: main:713: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Failed to create NvDsInferContext instance
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(914): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
[NvMultiObjectTracker] De-initialized
App run failed
Any help or advice would be appreciated!
The model input dim is different the input dim in your configure file. You need set the right value in config_infer_primary.txt based on your model.
I managed to get the model running but as you can see:
It seems there is a big bounding box around my entire RTSP stream. This model was built with 416x416 MAX dims. Do you think my camera is too far away?
How can I train this model on my own products, and would it be sufficient from this distance?
Regards,
PJ Pretorius.
What is the expect output of the model? Can you share more information about the model?
