Can't run DeepStream example
Hi everyone,
I’m new to NVIDIA DeepStream and am trying to get started by running the example app. However, I’m encountering several issues, and I’m unsure how to proceed.
deepstream-app -c /opt/nvidia/deepstream/deepstream-7.1/samples/configs/deepstream-app/source30_1080p_dec_infer-resnet_tiled_display_int8.txt
Setting min object dimensions as 16x16 instead of 1x1 to support VIC compute mode.
WARNING: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-7.1/samples/configs/deepstream-app/../../models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b30_gpu0_int8.engine open error
0:00:00.206619725 51130 0xaaaae43016f0 WARN                 nvinfer gstnvinfer.cpp:681:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2080> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-7.1/samples/configs/deepstream-app/../../models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b30_gpu0_int8.engine failed
0:00:00.206684489 51130 0xaaaae43016f0 WARN                 nvinfer gstnvinfer.cpp:681:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2185> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-7.1/samples/configs/deepstream-app/../../models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b30_gpu0_int8.engine failed, try rebuild
0:00:00.206704040 51130 0xaaaae43016f0 INFO                 nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2106> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: DLA requests all profiles have same min, max, and opt value. All dla layers are falling back to GPU
after that it just do nothing.
Jetson AGX Orin DevKit
• DeepStream Version
7.1
6.1
• TensorRT Version
10.7.0.23-1+cuda12.6
Bug/Question
Just run it 🤷🏻‍♂️
  1. For DS-7.1, it works on TRT 10.3, we have not tested it on TRT 10.7.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Installation.html#platform-and-os-compatibility
Building an engine file with a batch-size of 30 will take a lot of time.
Try source2_1080p_dec_infer-resnet_demux_int8.txt, or wait for the engine to be built successfully.
I suggest you try test1 first
cd /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test1/
make CUDA_VER=12.6
./deepstream-test1-app /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
Thank you for your response. I downgraded TensorRT to version 10.3, but the provided example (deepstream-app -c /opt/nvidia/deepstream/deepstream-7.1/samples/configs/deepstream-app/source30_1080p_dec_infer-resnet_tiled_display_int8.txt) still doesn’t work. The example (from this guide) shows the following warning:
WARNING: [TRT]: DLA requests all profiles have the same min, max, and opt value. All DLA layers are falling back to GPU.
However, the example you provided works fine.
Please ignore the warning. deepstream does not use DLA by default
Is there any error output?
If it doesn’t work, it’s probably because Jetpack is not installed correctly. Please use SDKManager to re-burn it.
https://docs.nvidia.com/sdk-manager/install-with-sdkm-jetson/index.html
