Retraining for One Particular Class Results in Detection of only that Class
I tried to enhance the “face” class in the PeopleNet trainable model v2.6 which can already detect persons, faces and bags due to the recall performance metric for the “face” class being noticeably low; hence, I trained the model by adding more images to the “face” class. Now, the trained model is only detecting faces but not persons, which was pretty good (high recall) prior to the training.
I retained all 3 existing classes in the specs, but the dataset I used for retraining consists of “face” class images only. Is it because of no layers are freezed (I don’t see any information in the training spec related to freezing layers); so, instead of transfer learning what I’ve done is actually a new training from the scratch or is freezing layers done automatically in TAO training? If the latter, then what might’ve caused this issue?
In a nutshell, retraining a model by adding more images to only one particular class (face) has resulted in the model detecting only that class (face) even though another class (person) had a good recall earlier.
• Hardware (T4)
• Network Type (Detectnet_v2)
• TLT Version (format_version: 2.0, toolkit_version: 3.22.05, published_date: 05/25/2022)
• Training spec file
random_seed: 42
dataset_config {
  data_sources {
    tfrecords_path: "/workspace/tao-experiments/data/tfrecords/kitti_trainval/*"
    image_directory_path: "/workspace/tao-experiments/data/training"
  image_extension: "png"
  target_class_mapping {
    key: "person"
    value: "person"
    key: "bag"
    value: "bag"
    key: "face"
    value: "face"
  validation_fold: 0
augmentation_config {
  preprocessing {
    output_image_width: 1248
    output_image_height: 384
    min_bbox_width: 1.0
    min_bbox_height: 1.0
    output_image_channel: 3
  spatial_augmentation {
    hflip_probability: 0.5
    zoom_min: 1.0
    zoom_max: 1.0
    translate_max_x: 8.0
    translate_max_y: 8.0
  color_augmentation {
    hue_rotation_max: 25.0
    saturation_shift_max: 0.20000000298
    contrast_scale_max: 0.10000000149
    contrast_center: 0.5
postprocessing_config {
  target_class_config {
    key: "person"
    value {
      clustering_config {
        clustering_algorithm: DBSCAN
        dbscan_confidence_threshold: 0.9
        coverage_threshold: 0.00499999988824
        dbscan_eps: 0.20000000298
        dbscan_min_samples: 0.0500000007451
        minimum_bounding_box_height: 20
    key: "bag"
    value {
      clustering_config {
        dbscan_eps: 0.15000000596
    key: "face"
    value {
      clustering_config {
        coverage_threshold: 0.00749999983236
        dbscan_eps: 0.230000004172
model_config {
  pretrained_model_file: "/workspace/tao-experiments/detectnet_v2/pretrained_peoplenet/peoplenet_vtrainable_v2.6/resnet34_peoplenet.tlt"
  num_layers: 18
  use_batch_norm: true
  objective_set {
    bbox {
      scale: 35.0
      offset: 0.5
    cov {
  arch: "resnet"
evaluation_config {
  validation_period_during_training: 10
  first_validation_epoch: 30
  minimum_detection_ground_truth_overlap {
    key: "person"
    value: 0.699999988079
    key: "bag"
    value: 0.5
    key: "face"
    value: 0.5
  evaluation_box_config {
    key: "person"
    value {
      minimum_height: 20
      maximum_height: 9999
      minimum_width: 10
      maximum_width: 9999
    key: "bag"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
    key: "face"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
  average_precision_mode: INTEGRATE
cost_function_config {
  target_classes {
    class_weight: 1.0
    coverage_foreground_weight: 0.0500000007451
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      initial_weight: 10.0
      weight_target: 10.0
  target_classes {
    class_weight: 8.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 1.0
  target_classes {
    class_weight: 4.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 10.0
  enable_autoweighting: true
  max_objective_weight: 0.999899983406
  min_objective_weight: 9.99999974738e-05
training_config {
  batch_size_per_gpu: 4
  num_epochs: 120
  learning_rate {
    soft_start_annealing_schedule {
      min_learning_rate: 5e-06
      max_learning_rate: 5e-04
      soft_start: 0.10000000149
      annealing: 0.699999988079
  regularizer {
    type: L1
    weight: 3.00000002618e-09
  optimizer {
    adam {
      epsilon: 9.99999993923e-09
      beta1: 0.899999976158
      beta2: 0.999000012875
  cost_scaling {
    initial_exponent: 20.0
    increment: 0.005
    decrement: 1.0
  visualizer{
    enabled: true
    num_images: 3
    scalar_logging_frequency: 50
    infrequent_logging_frequency: 5
      key: "person"
      value: {
        coverage_threshold: 0.005
      key: "bag"
      value: {
      key: "face"
      value: {
  checkpoint_interval: 10
bbox_rasterizer_config {
    key: "person"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 0.40000000596
      cov_radius_y: 0.40000000596
      bbox_min_radius: 1.0
    key: "bag"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
    key: "face"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
  deadzone_radius: 0.400000154972
• How to reproduce the issue ?
By adding more images to face class in PeopleNet trainable model v2.6 as provided in the Jupyter notebook (DetectNet v2 sample)
If the dataset used for retraining consists of “face” class images only, the trained model can only detect faces.
If that’s the case, what are the ways to improve the accuracy for a particular class?
If aims to train 3 classes, it is needed to prepare the dataset of these 3 classes.
If aims to train only one particular class, just need to train with this class’s data.
