I was wondering if it’s OK to leave resources mapped/registered while copying into an NvBuffer. My program maintains a cache of NvBuffers in order to avoid continually creating and destroying them. On each acquired frame I call copyToNvBuffer to copy the new image into one of the cached buffers (perform block linear to pitch linear conversion and scaling). After that I access the image on the cpu or in cuda to perform processing. Rough pseudo-code would be:
function createNvBuffers()
for (i=0; i<num_buffers; ++i)
NvBufferCreateEx()
function destroyNvBuffers()
NvBufferDestroy()
function process_image(my_buffer)
// do some processing
cuGraphicsUnregisterResource()
NvDestroyEGLImage()
NvBufferMemUnMap() - for y/u/v planes
return_buffer_to_cache(my_buffer)
function main()
cache = createNvBuffers()
while (run)
acquire_frame()
my_buffer = get_free_nvbuffer_from_cache()
iNativeBuffer->copyToNvBuffer(my_buffer)
NvBufferMemMap() + NvBufferMemSyncForCpu() - for y/u/v planes
NvEGLImageFromFd()
cuGraphicsEGLRegisterImage()
cuGraphicsResourceGetMappedEglFrame()
process_image(my_buffer) - runs processing in another thread
destroyNvBuffers(cache)
NvBufferMemMap + NvEGLImageFromFd + cuGraphicsEGLRegisterImage + cuGraphicsResourceGetMappedEglFrame take a non-negligible amount of time. Is it safe to perform those steps just once on buffer creation? Changing the code to:
NvBufferCreateEx()
NvBufferMemMap() - for y/u/v planes
NvEGLImageFromFd()
NvDestroyEGLImage()
NvBufferDestroy()
// do processing
function main()
while (run)
acquire_frame()
My processing only reads the image data (either in cuda or on the cpu). It doesn’t modify the data if that matters. Based on documentation this seems safe, but it wasn’t completely clear.
