RGB/BGR input format specified but network input channels is not 3
• Hardware Platform (Jetson / GPU): Jetson AGX Orin Dev Kit
• DeepStream Version: 6.3
• JetPack Version (valid for Jetson only): 5.1.2
• TensorRT Version: 8.5.2
• NVIDIA GPU Driver Version (valid for GPU only): R35.6.0
• Issue Type( questions, new requirements, bugs): questions
Problem:
fpascal@ubuntu:~/tiscamera/build$ gst-launch-1.0 \
tcambin name=tcam0 ! video/x-raw,format=GRAY8,width=1920,height=1080,framerate=30/1
! videoconvert ! “video/x-raw,format=BGR”
! nvvideoconvert ! “video/x-raw(memory:NVMM),format=NV12,width=1920,height=1080”
! mux.sink_0 nvstreammux name=mux batch-size=1 width=1920 height=1080 live-source=1
! nvinfer config-file-path=$HOME/my_code/config_infer_primary.txt
! nvvidconv ! nvdsosd
! nvvideoconvert ! “video/x-raw(memory:NVMM),format=NV12”
! nvv4l2h264enc bitrate=2000000
! h264parse ! mp4mux
! filesink location=$HOME/Videos/output.mp4 -e
Setting pipeline to PAUSED …
Opening in BLOCKING MODE
0:00:03.507798404 483809 0xaaaad914fa40 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1174> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:06.302814168 483809 0xaaaad914fa40 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 1]: deserialized trt engine from :/home/fpascal/my_code/model.engine
WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_6 224x224x3
1 OUTPUT kFLOAT cls 10x4
2 OUTPUT kFLOAT bbox 10x4
0:00:06.470124552 483809 0xaaaad914fa40 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 1]: Use deserialized engine model: /home/fpascal/my_code/model.engine
0:00:06.470188174 483809 0xaaaad914fa40 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::preparePreprocess() <nvdsinfer_context_impl.cpp:974> [UID = 1]: RGB/BGR input format specified but network input channels is not 3
ERROR: Infer Context prepare preprocessing resource failed., nvinfer error:NVDSINFER_CONFIG_FAILED
0:00:06.477269765 483809 0xaaaad914fa40 WARN nvinfer gstnvinfer.cpp:898:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:06.477317674 483809 0xaaaad914fa40 WARN nvinfer gstnvinfer.cpp:898:gst_nvinfer_start: error: Config file path: /home/fpascal/my_code/config_infer_primary.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
ERROR: Pipeline doesn’t want to pause.
ERROR: from element /GstPipeline:pipeline0/GstNvInfer:nvinfer0: Failed to create NvDsInferContext instance
Additional debug info:
/dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(898): gst_nvinfer_start (): /GstPipeline:pipeline0/GstNvInfer:nvinfer0:
Setting pipeline to NULL …
Freeing pipeline ...
Config file
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-engine-file=/home/fpascal/my_code/model.engine
labelfile-path=/home/fpascal/my_code/labels.txt
batch-size=1
process-mode=1
model-color-format=0
network-mode=2
num-detected-classes=4
interval=0
gie-unique-id=1
force-implicit-batch-dim=0
infer-dims=224;224;3
[class-attrs-all]
topk=20
nms-iou-threshold=0.5
pre-cluster-threshold=0.2
From the model. the network-input-order should be set to 1, meaning NHWC. please modify infer-dims=224;224;3 to infer-dims=3:224;224 because it needs “3 as [c;h;w] order”.
Its my understanding that network‑input‑order only takes two values:
  • 0 → NCHW layout
    • model’s input tensor is laid out as [N,C,H,W].
    • In this case, infer‑dims should be specified as H;W;C (e.g. 224;224;3).
  • 1 → NHWC layout
    • model expects [N,H,W,C].
    • infer‑dimsmust beC;H;W(e.g.3;224;224`).
Made the changes use suggested but still receiving the below errors:
fpascal@ubuntu:~/tiscamera/build$ **t-launch-1.0 \
! nvvideoconvert compute-hw=GPU ! “video/x-raw(memory:NVMM),format=NV12,width=1920,height=1080”
! nvvidconv ! “video/x-raw(memory:NVMM),format=NV12,width=1920,height=1080”
! nvvideoconvert compute-hw=GPU copy-hw=GPU gpu-id=0 nvbuf-memory-type=0
0:00:01.759088721 7382 0xaaaae8a6ff50 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1174> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:04.522379878 7382 0xaaaae8a6ff50 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 1]: deserialized trt engine from :/home/fpascal/my_code/model.engine
0:00:04.692663215 7382 0xaaaae8a6ff50 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 1]: Use deserialized engine model: /home/fpascal/my_code/model.engine
0:00:04.720985103 7382 0xaaaae8a6ff50 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus: [UID 1]: Load new model:/home/fpascal/my_code/config_infer_primary.txt sucessfully
Pipeline is live and does not need PREROLL …
INFO:
Working with src caps: video/x-raw, format=(string)GRAY8, width=(int)1920, height=(int)1080, framerate=(fraction)30/1
Setting pipeline to PLAYING …
New clock: GstSystemClock
Redistribute latency…
NvMMLiteOpen : Block : BlockType = 4
===== NvVideo: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
0:00:05.211424894 7382 0xaaaae8a69c00 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::parseBoundingBox() <nvdsinfer_context_impl_output_parsing.cpp:59> [UID = 1]: Could not find output coverage layer for parsing objects
0:00:05.211478400 7382 0xaaaae8a69c00 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::fillDetectionOutput() <nvdsinfer_context_impl_output_parsing.cpp:735> [UID = 1]: Failed to parse bboxes
Caught SIGSEGV
Spinning.
Config file
[property]
gpu-id=0
batch-size=1
process-mode=1
network-mode=2
interval=0
gie-unique-id=1
# Tech‑Support wants NHWC mode, dims in [C;H;W]:
network-input-order=1
infer-dims=3;224;224
output-blob-names=cls;bbox
parse-bbox-func-name=NvDsInferParseCustomTFOD
[class-attrs-all]
topk=20
This is a new error. The default postprocess funtion is for resnet10 model. Notcing parse-bbox-func-name is set, you also need to set custom-lib-path, please refer to this cfg.
