Riva C++ examples
In the Riva docs:
https://docs.nvidia.com/deeplearning/riva/user-guide/docs/development-client-image.html#c-streaming-example
On this page, it refers readers to two cpp examples:
riva_streaming_asr_client.cc
riva_asr_client.cc
However, these files are not in the riva docker container, but the python examples are. Where can these files be found that are referred to in the docs?
Hi @BGreenway ,
This is referring to cpp clients inside docker.
These are the cpp binary files,If you want to see the more options Just run the command:
riva_streaming_asr_client --help
Disappointing that you don’t share the source for these examples; after all, this is all meant for developers, and binary demo applications aren’t much help without the source. Regardless, I appreciate all the tools that you do provide. Thanks for the response.
@BGreenway the source for these clients are now available on GitHub: GitHub - nvidia-riva/cpp-clients: Sample C++ command-line Riva clients..
