Hardware - GPU (T4)
Operating System ubuntu
Riva Version 1.5.0
Hi So I’m trying to run the citrinet pre-trained model with custom configs, but when adding a language model (Riva ASR English LM | NVIDIA NGC where I got the language model ) the riva_start always times out and fails:
Log when running riva_start (I did initialise the model by using the quickstart script)
E0911 13:32:58.027425 73 sequence_batch_scheduler.cc:941] Initialization failed for Direct sequence-batch scheduler thread 0: initialize error for 'citrinet-ctc-decoder-cpu-streaming': (13) Invalid parameters in model configuration
Can you please tell me what the invalid parameters are? The riva-build was successful btw.
Hi, thanks for the reply @AakankshaS , but is it possible to use the above command for the language model ? Or do I have to create a new language model with tao ?
