Hardware - GPU: DGX A100 Workstation
Hardware - CPU:
Operating System: Ubuntu 20.04
Riva Version: 1.8.0-beta
Hi. I’m trying to follow the instructions on the doc to run the sample application of virtual assistant.
I ran both riva_init.sh
and riva_start.sh
well and made the following containers up-running:
riva-speech:1.8.0-beta-server
and
riva-speech-client:1.8.0-beta-samples
Afterwards, I changed config.py
in the container and browsed https://127.0.0.1:8009/rivaWeather/
on Firefox (version 91.0, 64 bit) as the doc instructions said, however, after submitting the first sentence on the UI, I got an error saying that there is an error during a service call.
Is there anyone who knows how to address this issue? I have no clues on what’s going wrong over here.
Here is the error I got:
root@93c0b2a882cb:/workspace/samples/virtual-assistant# python3 main.py
Server starting at : https://0.0.0.0:8009/rivaWeather
Note: Currently the streaming is working with Chrome and FireFox, Safari does not support navigator.mediaDevices.getUserMedia
[Riva Chatbot] Client connected
[stateDM] Initializing the state machine for uid: 1
[1] Starting chatbot ASR task
[1] ASR background task started
[Riva Chatbot] Chatbot created with user conversation index:[1]
[stateDM] Executing state: initialState
[Riva ASR] Creating Stream ASR channel: 172.0.0.1:50051
[1] Response from RivaDM: {‘context’: {}, ‘text’: ‘’, ‘uid’: 1, ‘payload’: {}, ‘response’: [{‘type’: ‘text’, ‘payload’: {‘text’: ‘Hi, welcome to Riva weather service. How may I help you?’}, ‘delay’: 0}]}
[Riva ASR] Starting Background ASR process
[Riva ASR] StreamingRecognize Start
[1] TTS Disabled
[1] audio speak: 1641896536160
[1] Pausing ASR requests.
[1] Attempt at Unpausing ASR requests on REQUEST_COMPLETE.
[1] ASR successfully unpaused for Request Complete
[stateDM] Executing state: userInput
[1] Pausing ASR requests.[Riva NLU] Error during NLU request
[stateDM] No next state, waiting for user input
[1] Response from RivaDM: {‘context’: {}, ‘text’: ‘What is the weather today?’, ‘uid’: 1, ‘payload’: {}}
‘response’
Exception in thread Thread-6:
File “/usr/lib/python3.8/threading.py”, line 932, in _bootstrap_inner
self.run()
File “/usr/lib/python3.8/threading.py”, line 870, in run
self._target(*self._args, **self._kwargs)
File “/workspace/samples/virtual-assistant/riva/chatbot/chatbot.py”, line 33, in server_asr
self.asr.main_asr()
File “/workspace/samples/virtual-assistant/riva/asr/asr.py”, line 180, in main_asr
self.listen_print_loop(responses)
File “/workspace/samples/virtual-assistant/riva/asr/asr.py”, line 109, in listen_print_loop
for response in responses:
File “/usr/local/lib/python3.8/dist-packages/grpc/_channel.py”, line 392, in next
return self._next()
File “/usr/local/lib/python3.8/dist-packages/grpc/_channel.py”, line 561, in _next
raise self
grpc._channel._Rendezvous: <_Rendezvous of RPC that terminated with:
status = StatusCode.UNAVAILABLE
details = “failed to connect to all addresses”
debug_error_string = “{“created”:”@1641896556.152911446",“description”:“Failed to pick subchannel”,“file”:“src/core/ext/filters/client_channel/client_channel.cc”,“file_line”:3934,“referenced_errors”:[{“created”:“@1641896556.152908601”,“description”:“failed to connect to all addresses”,“file”:“src/core/ext/filters/client_channel/lb_policy/pick_first/pick_first.cc”,“file_line”:393,“grpc_status”:14}]}"
and here is the screenshot of the application UI
here is the screenshot of the config.py that I modified
