Hi expert
I am using rivermax sdk example codes, but get cuMemSetAccess failed
CODE: media_sender.exe(Release-CUDA)
GPU: NVIDIA RTX A4000
CUDA: 12.1
Driver: 531.14
wiindows: 10 rpo 21H2
RUN CMD: .\media_sender.exe -c 1 -a 2 -s .\sdps_samples\sdp_2110-20_narrow_gap_1080p50fps.txt -g 0 -r --max_gpu_freq
/logs as follows*****************/
Rivermax SDK version: 1.30.16
Media sender version: 1.30.16
Set env variable CUDA_DEVICE_ORDER=PCI_BUS_ID
gpu_device_id = 0
Writing log to default location: C:\Users\Administrator\AppData\Local\Temp\rivermax_0605_095514_5904.log
Created log file: C:\Users\Administrator\AppData\Local\Temp\rivermax_0605_095514_5904.log
[23-06-05 09:55:14.856135] Tid: 003972 info [InitLogger:92] Logger started
[23-06-05 09:55:14.856164] Tid: 003972 info [rmax_init:610] starting Rivermax: SDK version 1.30.16
[23-06-05 09:55:14.857025] Tid: 003972 debug [Clock:31]
[23-06-05 09:55:14.857044] Tid: 003972 debug [SysClock:41]
[23-06-05 09:55:14.857062] Tid: 003972 debug [rivermax_get_user_env:151] parsed env RIVERMAX_DISABLE_VIDEO_GROUPING to the value true
[23-06-05 09:55:14.857085] Tid: 003972 debug [rivermax_get_user_env:151] parsed env RIVERMAX_VIDEO_PACE_INTERVAL to the value 1000000
[23-06-05 09:55:14.857287] Tid: 003972 debug [rivermax_get_user_env:151] parsed env RIVERMAX_OUT_STREAM_SIZE_IN_PKTS to the value 32768
[23-06-05 09:55:14.857309] Tid: 003972 debug [rivermax_get_user_env:151] parsed env RIVERMAX_HEADER_STRIDE_SIZE to the value 64
[23-06-05 09:55:14.857329] Tid: 003972 debug [rivermax_get_user_env:151] parsed env RIVERMAX_DISABLE_FLOW_ID to the value false
[23-06-05 09:55:14.857348] Tid: 003972 debug [rivermax_get_user_env:151] parsed env RIVERMAX_SDP_PARSER_ENABLE_LOGGING to the value true
[23-06-05 09:55:14.857368] Tid: 003972 debug [rivermax_get_user_env:151] parsed env RIVERMAX_ENABLE_PTP_HW_RT_CLOCK to the value false
[23-06-05 09:55:14.857503] Tid: 003972 debug [rivermax_get_user_env:151] parsed env RIVERMAX_ENABLE_CUDA to the value true
[23-06-05 09:55:14.857526] Tid: 003972 debug [rivermax_get_user_env:151] parsed env RIVERMAX_ENABLE_STATISTICS to the value false
[23-06-05 09:55:14.857547] Tid: 003972 debug [rivermax_get_user_env:151] parsed env RIVERMAX_ENABLE_API_VERIFICATION to the value false
[23-06-05 09:55:14.857567] Tid: 003972 debug [rivermax_get_user_env:151] parsed env RIVERMAX_DISABLE_AUDIO_BUFFERING to the value false
[23-06-05 09:55:14.857785] Tid: 003972 debug [rivermax_get_user_env:151] parsed env RIVERMAX_SESSION_MAP_SIZE to the value 2000
[23-06-05 09:55:14.857819] Tid: 003972 debug [rivermax_get_user_env:151] parsed env RIVERMAX_SESSION_MAP_SIZE to the value 2000
[23-06-05 09:55:14.858010] Tid: 003972 debug [EventHandlerManager:125]
[23-06-05 09:55:14.858224] Tid: 003972 info [EventHandlerManager:132] will wakeup before frame begin event in 2000000 ns
[23-06-05 09:55:14.858244] Tid: 003972 debug [EventHandlerManagerHigh:259]
[23-06-05 09:55:14.858262] Tid: 003972 debug [start_thread:341] Starting internal thread
[23-06-05 09:55:14.858301] Tid: 003972 debug [rivermax_set_thread_affinity:719] successfully set thread affinity using cpu mask: 0x2, previous mask: 0xff
[23-06-05 09:55:14.858329] Tid: 003972 debug [start_thread:344] Started event handler thread
[23-06-05 09:55:14.858355] Tid: 003972 debug [init_globals:249] Time now is 1685930114858355500
[23-06-05 09:55:14.858947] Tid: 001968 info [print_thread_info:117] High priority internal thread: PID = 5904, thread ID = 1968
[23-06-05 09:55:14.859747] Tid: 003972 debug [load_provider:69] dpcp[0] = 6008005000000 ‘Mellanox ConnectX-6 Dx Adapter’
[23-06-05 09:55:14.859959] Tid: 003972 debug [load_provider:69] dpcp[1] = 6008006000000 ‘Mellanox ConnectX-6 Dx Adapter #2’
[23-06-05 09:55:14.860177] Tid: 003972 info [init:37] DPCP/DevX provider was loaded
[23-06-05 09:55:14.919350] Tid: 003972 debug [getAdapterInfo:473] Adapter 以太网 2 vlanId 0 len 6 MAC 04:3f:72:a4:99:94
[23-06-05 09:55:14.925612] Tid: 003972 debug [getAdapterInfo:511] LUID 6008005000000 0x15b3/0x101d dpcp_adapter 0x1d173dc5cf0 opened true ret 0
[23-06-05 09:55:14.925961] Tid: 003972 debug [getAdapterInfo:528] IP: 192.168.5.114 VLAN_ID: 0 Serial number: MT2035X03236
[23-06-05 09:55:14.926026] Tid: 003972 debug [getAdapterInfo:530] MTU: 1500 TXlinkSpeed: 100 Gbps RXLinkSpeed:100 Gbps
[23-06-05 09:55:14.926326] Tid: 003972 info [getAdapterInfo:535] Device with IP addr: 192.168.5.114 was added to Device Collection [1]
[23-06-05 09:55:14.926563] Tid: 003972 warning [getAdapterInfo:430] Adapter 以太网 3 luidIdx 0x8006 is not Up
[23-06-05 09:55:14.929496] Tid: 003972 debug [getAdapterInfo:473] Adapter 以太网 3 vlanId 0 len 6 MAC 04:3f:72:a4:99:95
[23-06-05 09:55:14.933520] Tid: 003972 debug [getAdapterInfo:511] LUID 6008006000000 0x15b3/0x101d dpcp_adapter 0x1d173e121e0 opened true ret 0
[23-06-05 09:55:14.934033] Tid: 003972 debug [getAdapterInfo:528] IP: 169.254.42.137 VLAN_ID: 0 Serial number: MT2035X03236
[23-06-05 09:55:14.934059] Tid: 003972 debug [getAdapterInfo:530] MTU: 1500 TXlinkSpeed: 18446744073 Gbps RXLinkSpeed:18446744073 Gbps
[23-06-05 09:55:14.934267] Tid: 003972 info [getAdapterInfo:535] Device with IP addr: 169.254.42.137 was added to Device Collection [2]
[23-06-05 09:55:14.936009] Tid: 003972 debug [getAdapterInfo:473] Adapter 以太网 vlanId 0 len 6 MAC 04:d4:c4:06:38:25
[23-06-05 09:55:14.936036] Tid: 003972 debug [getAdapterInfo:515] DPCP device with LUID 6008001000000 not found!
[23-06-05 09:55:14.936236] Tid: 003972 info [~winDevice:97] ~winDevice DTOR
[23-06-05 09:55:14.938938] Tid: 003972 debug [getAdapterInfo:473] Adapter Loopback Pseudo-Interface 1 vlanId 0 len 0 MAC 00:00:00:00:00:00
[23-06-05 09:55:14.943206] Tid: 003972 debug [GetPhysicalAdapterByMAC:358] No physical device found, bypassing
[23-06-05 09:55:14.943267] Tid: 003972 debug [getAdapterInfo:486] Physical adapter GUID wasn’t found, bypassing
[23-06-05 09:55:14.943536] Tid: 003972 info [~winDevice:97] ~winDevice DTOR
[23-06-05 09:55:14.969048] Tid: 003972 info [license_validate_v4:446] Licensed to: Beijing Enlightv Co., Ltd (N/A), evaluation period expires in 25 days
[23-06-05 09:55:14.969122] Tid: 003972 info [info_product:466] Rivermax license version: 4.1
[23-06-05 09:55:14.969834] Tid: 003972 info [license_validate:516] Rivermax license id 827d7712-80a4-1938-6474-902c070f7f24, revision 1
[23-06-05 09:55:14.970095] Tid: 003972 info [rmax_init:638] Statistics disabled
[23-06-05 09:55:14.970294] Tid: 003972 info [cuda_enable_etbl:362] Starting Cuda init
[23-06-05 09:55:14.970509] Tid: 003972 info [cuda_enable_etbl:396] Cuda init Done
List of supported devices:
Device with interface name: 以太网 3, IP addresses: [ 169.254.42.137 ], MAC address: 04:3f:72:a4:99:95, device_id: 4125, serial number: MT2035X03236
Device with interface name: 以太网 2, IP addresses: [ 192.168.5.114 ], MAC address: 04:3f:72:a4:99:94, device_id: 4125, serial number: MT2035X03236
[23-06-05 09:55:14.972290] Tid: 003972 debug [Clock:31]
[23-06-05 09:55:14.972649] Tid: 003972 debug [ExternalClock:66]
[23-06-05 09:55:14.972669] Tid: 003972 debug [~SysClock:46]
[23-06-05 09:55:14.972683] Tid: 003972 debug [~Clock:36]
[23-06-05 09:55:14.972871] Tid: 003972 debug [rmx_use_user_clock_v1:324] Using user time handler
TX Thread: 0 Mask: 0x4
CUDA memory allocation on GPU - cuMemCreate
RDMA is supported and enabled, status
cuMemSetAccess failed status = 999
CUDA cudaFreeMmap 304600000
CUDA memory free finished with status 1
Failed to allocate GPU memory.
Failed to allocate memory on GPU id 0
Failed to allocate memory with size: 62914560
thread 0 initialization failed
[23-06-05 09:55:15.060593] Tid: 003972 info [rmax_cleanup:689] Cleanup called
[23-06-05 09:55:15.060819] Tid: 003972 debug [~EventHandlerManagerHigh:265]
[23-06-05 09:55:15.061004] Tid: 003972 debug [~EventHandlerManager:139]
[23-06-05 09:55:15.061203] Tid: 003972 debug [free_evh_resources:148]
[23-06-05 09:55:15.061479] Tid: 003972 debug [stop_thread:163] event handler thread stopped
[23-06-05 09:55:15.061606] Tid: 003972 debug [free_evh_resources:152] Thread stopped
[23-06-05 09:55:15.061908] Tid: 003972 debug [~ExternalClock:71]
[23-06-05 09:55:15.062005] Tid: 003972 debug [~Clock:36]
[23-06-05 09:55:15.062205] Tid: 003972 debug [~DeviceCollection:28] ~DeviceCollection()
[23-06-05 09:55:15.062406] Tid: 003972 info [~winDevice:97] ~winDevice DTOR
[23-06-05 09:55:15.062918] Tid: 003972 info [~winDevice:97] ~winDevice DTOR
[23-06-05 09:55:15.063158] Tid: 003972 info [~RiverLogger:105] logger closing
