[1635322.217728] NVRM: RmInitAdapter failed! (0x25:0x65:1084)
[1635322.217758] NVRM: rm_init_adapter failed for device bearing minor number 0
[1635382.223013] NVRM: RmInitAdapter failed! (0x25:0x65:1084)
[1635382.223041] NVRM: rm_init_adapter failed for device bearing minor number 0
[1635442.228332] NVRM: RmInitAdapter failed! (0x25:0x65:1084)
[1635442.228364] NVRM: rm_init_adapter failed for device bearing minor number 0
[1635502.221568] NVRM: RmInitAdapter failed! (0x25:0x65:1084)
[1635502.221619] NVRM: rm_init_adapter failed for device bearing minor number 0
[1635562.222894] NVRM: RmInitAdapter failed! (0x25:0x65:1084)
[1635562.222930] NVRM: rm_init_adapter failed for device bearing minor number 0
[1635622.216227] NVRM: RmInitAdapter failed! (0x25:0x65:1084)
[1635622.216261] NVRM: rm_init_adapter failed for device bearing minor number 0
[1635682.225549] NVRM: RmInitAdapter failed! (0x25:0x65:1084)
[1635682.225580] NVRM: rm_init_adapter failed for device bearing minor number 0
[1635742.230844] NVRM: RmInitAdapter failed! (0x25:0x65:1084)
[1635742.230872] NVRM: rm_init_adapter failed for device bearing minor number 0
[1635802.228230] NVRM: RmInitAdapter failed! (0x25:0x65:1084)
[1635802.228259] NVRM: rm_init_adapter failed for device bearing minor number 0
[1635862.229690] NVRM: RmInitAdapter failed! (0x25:0x65:1084)
[1635862.229728] NVRM: rm_init_adapter failed for device bearing minor number 0
[1635922.230725] NVRM: RmInitAdapter failed! (0x25:0x65:1084)
[1635922.230790] NVRM: rm_init_adapter failed for device bearing minor number 0
[1635982.240126] NVRM: RmInitAdapter failed! (0x25:0x65:1084)
[1635982.240153] NVRM: rm_init_adapter failed for device bearing minor number 0
[1636042.237361] NVRM: RmInitAdapter failed! (0x25:0x65:1084)
[1636042.237419] NVRM: rm_init_adapter failed for device bearing minor number 0
[1636067.405883] NVRM: RmInitAdapter failed! (0x25:0x65:1084)
[1636067.405909] NVRM: rm_init_adapter failed for device bearing minor number 0
$ nvidia-smi
Fri Feb 21 09:11:33 2020
| NVIDIA-SMI 418.56 Driver Version: 418.56 CUDA Version: 10.1 |
| 0 GeForce GTX 108… Off | 00000000:03:00.0 Off | N/A |
| 14% 31C P0 51W / 250W | 0MiB / 11178MiB | 0% Default |
| 1 GeForce GTX 108… Off | 00000000:82:00.0 Off | N/A |
| 13% 29C P0 51W / 250W | 0MiB / 11178MiB | 0% Default |
| 2 GeForce GTX 108… Off | 00000000:83:00.0 Off | N/A |
| 13% 32C P0 55W / 250W | 0MiB / 11178MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
What should I do?
