The issue:
I want to run an application that uses Multicast on top of RoCEv1 (version 1) but the packets are dropped in the switch - the cause of the drop is “Multicast egress port list is empty”
I’m using IGMP snooping:
Heron [standalone: master] (config vlan 1) # show ip igmp snooping groups
Vlan ID Group St/Dyn Ports
1 239.255.255.240 Dyn Eth1/5
Total Num of Dynamic Group Addresses: 1
Total Num of Static Group Addresses : 0
note: multicast is working on RoCEv2 but is not on RoCEv1.
after running show what-just-happened in the switch:
I get that the reason for dropping is: Multicast egress port list is empty
what does this drop reason mean? and what is missing in the switch configuration to make multicast works on top of RoCEv1?
Heron [standalone: master] (config) # show version
Product name: Onyx
Product release: 3.8.2008
Build ID: #1-dev
Build date: 2019-11-19 11:15:58
Target arch: x86_64
Target hw: x86_64
Built by: jenkins@27900d252c67
Version summary: X86_64 3.8.2008 2019-11-19 11:15:58 x86_64
Product model: x86onie
Host ID: 248A07912B0C
System serial num: MT1706X01027
System UUID: fcd6da7c-2e4a-11e7-8000-248a07f36740
Uptime: 11d 19h 23m 50.784s
CPU load averages: 3.02 / 3.05 / 3.04
Number of CPUs: 2
System memory: 2376 MB used / 5413 MB free / 7789 MB total
Swap: 0 MB used / 0 MB free / 0 MB total
