Hi
I want to install ROS on my PX2.
I follow the DRIVE PX2 ROS INSTALLATION(https://devtalk.nvidia.com/default/topic/1032204/faq/drive-px2-ros-installation/post/5251398/#5251398), and install successfully.
But I can’t run
$ roslaunch turtle_tf turtle_tf_demo.launch
It show error like below
[turtle_tf_demo.launch] is neither a launch file in package [turtle_tf] nor is [turtle_tf] a launch file name
The traceback for the exception was written to the log file
I have already checked ~/.bashrc and ~/.profile to confirm step9 and step10. It show like bellow.And roscore can work.
~/.bashrc
# Alias definitions.
# You may want to put all your additions into a separate file like
# ~/.bash_aliases, instead of adding them here directly.
# See /usr/share/doc/bash-doc/examples in the bash-doc package.
if [ -f ~/.bash_aliases ]; then
. ~/.bash_aliases
fi
# enable programmable completion features (you don't need to enable
# this, if it's already enabled in /etc/bash.bashrc and /etc/profile
# sources /etc/bash.bashrc).
if ! shopt -oq posix; then
if [ -f /usr/share/bash-completion/bash_completion ]; then
. /usr/share/bash-completion/bash_completion
elif [ -f /etc/bash_completion ]; then
. /etc/bash_completion
fi
fi
export PATH=/usr/local/cuda-9.0/bin/:$PATH
export LD_LIBRARY_PATH=/usr/local/cuda/targets/aarch64-linux/lib:$LD_LIBRARY_PATH
source /opt/ros/kinetic/setup.bash
~/.profile
# ~/.profile: executed by the command interpreter for login shells.
# Copyright (c) 2017, NVIDIA CORPORATION. All rights reserved.
# This file is not read by bash(1), if ~/.bash_profile or ~/.bash_login
# exists.
# see /usr/share/doc/bash/examples/startup-files for examples.
# the files are located in the bash-doc package.
# the default umask is set in /etc/profile; for setting the umask
# for ssh logins, install and configure the libpam-umask package.
#umask 022
# if running bash
if [ -n "$BASH_VERSION" ]; then
# include .bashrc if it exists
if [ -f "$HOME/.bashrc" ]; then
. "$HOME/.bashrc"
fi
fi
# set PATH so it includes user's private bin if it exists
if [ -d "$HOME/bin" ] ; then
PATH="$HOME/bin:$PATH"
fi
export XAUTHORITY=/home/nvidia/.Xauthority
export LD_LIBRARY_PATH=/usr/lib:/usr/lib/aarch64-linux-gnu
# execute drive-setup.sh if it exist
if [ -f /root/drive-setup.sh ]; then
fi
Information about our set-up:
Dear allenchen8210,
Could you please run below command instead of echo “source /opt/ros/kinetic/setup.bash” >> ~/.bashrc in step9?
echo source /opt/ros/kinetic/setup.bash >> ~/.bashrc
source ~/.bashrc
hi, SteveNV
thank u for reply
here is my command, still have error.
nvidia@nvidia:~$ echo source /opt/ros/kinetic/setup.bash >> ~/.bashrc
nvidia@nvidia:~$ source ~/.bashrc
nvidia@nvidia:~$ roslaunch turtle_tf turtle_tf_demo.launch
./bashrc
Really thank u for ur help
# some more ls aliases
alias ll='ls -alF'
alias la='ls -A'
alias l='ls -CF'
# Add an "alert" alias for long running commands. Use like so:
# sleep 10; alert
alias alert='notify-send --urgency=low -i "$([ $? = 0 ] && echo terminal || echo error)" "$(history|tail -n1|sed -e ''s/^\s*[0-9]\s*//;s/[;&|]\s*alert$//'')"'
. ~/.bash_aliases
fi
fi
fi
Dear allenchen8210,
Could you please attach a log via history command?
Hi SteveNV, here is my history command.
1244 weget https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/sources.list.d/20-default.list
1245 wget https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/sources.list.d/20-default.list
1246 wget --no-check-certificate https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/sources.list.d/20-default.list
1247 sudo apt-get install ca-certificates
1248 sudo c_rehash /etc/ssl/certs
1249 rosdep init
1250 sudo easy_install pip
1251 apt-cache search ros-kinetic
1252 sudo rosdep init
1253 rosdep update
1254 sudo rosdep update
1255 sudo rosdep init
1256 sudo apt-get install ros-kinetic-desktop-full
1257 rviz &
1258 rviz&
1259 rosversion -d
1260 echo $ROS_DOSTRO
1261 sudo apt-get install libssl1.0.0/xenial libssl-doc/xenial libssl-dev/xenial
1262 htop sudo apt-get install ros-kinetic-desktop
1263 sudo apt-get install ros-kinetic-desktop
1264 echo “source /opt/ros/kinetic/setup.bash” >> ~/.bashrc
1265 source ~/.bashrc
1266 echo "source /opt/ros/kinetic/setup.bash" >> ~/.bashrc
1267 source ~/.bashrc
1268 sudo source ~/.bashrc
1269 sudo -s
1270 bash: “source: command not found
1271 source ~/.bashrc
1272 source ~/.bashrc
1273 sudo -s
1274 sudo -s source ~/.bashrc
1275 export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib:/usr/lib/aarch64-linux-gnu
1276 roslaunch turtle_tf turtle_tf_demo.launch
1277 rosversion -d
1278 % sudo apt-get install -y python-catkin-pkg python-rosdep python-wstool ros-$ROS_DISTRO-catkin libmosquitto-dev gksu
1279 cd $HOME
1280 ls
1281 cd Autoware/ros/
1282 rosdep update
1283 sudo rosdep init
1284 cd src/
1285 catkin_init_workspace
1286 cd ../
1287 rosdep update
1288 rosdep install -y --from-paths src --ignore-src --rosdistro $ROS_DISTRO
1289 sudo rosdep init
1290 sudo -E rosdep init
1291 sudo rosdep init
1292 rosdep update
1293 ./catkin_make_release
1294 rosdep install -y --from-paths src --ignore-src --rosdistro $ROS_DISTRO
1295 ls
1296 ./run
1297 python
1298 python3
1299 pip install psutil
1300 python
1301 pip install psutil
1302 ./run
1303 which easy_install
1304 pip install psutil
1305 sudo pip install psutil
1306 ./run
1307 ls
1308 cd Autoware/ros/
1309 ./run
1310 sudo ./run
1311 sudo apt-get install python-wxtools
1312 sudo apt autoremove
1313 sudo apt-get install python-wxtools
1314 pip install -U colcon-common-extensions
1315 sudo pip install -U colcon-common-extensions
1316 source /opt/ros/indigo/setup.bash
1317 ls
1318 roscore
1319 cd Autoware/ros/
1320 ls
1321 source devel/setup.bash
1322 ./run
1323 cd ..
1324 ls
1325 source devel/setup.bash
1326 cd ros/
1327 source devel/setup.bash
1328 catkin_package_version
1329 ls
1330 exit
1331 htop
1332 exit
1333 cd Autoware/ros/
1334 ./run
1335 cd src/
1336 catkin_init_workspace
1337 cd .
1338 cd ..
1339 ls
1340 ./catkin_make_release
1341 rosdep update
1342 rosdep install -y --from-paths src --ignore-src --rosdistro $ROS_DISTRO
1343 ./catkin_make_release
1344 ./run
1345 source /opt/ros/indigo/setup.bash
1346 ls
1347 ./colcon_release
1348 vim colcon_release
1349 ./colcon_release
1350 ./run
1351 sudo apt-get install -y python3-pip python3-setuptools
1352 sudo pip3 install -U setuptools
1353 cd Autoware/ros/
1354 ls
1355 ./colcon_release
1356 ros
1357 roscore
1358 ./camera_test
1359 rostopic list
1360 rostopic echo /image_raw
1361 ./run
1362 roslaunch autoware_driveworks_gmsl_interface multi_gmsl.launch
1363 roslaunch multi_gmsl.launch
1364 roslaunch autoware_driveworks_gmsl_interface multi_gmsl.launch
1365 rosnode list
1366 rosrun turtlesim turtlesim_node
1367 $ sudo apt-get install ros-<distro>-ros-tutorials
1368 $ sudo apt-get install ros-<kinetic>-ros-tutorials
1369 $ sudo apt-get install ros-kinetic-ros-tutorials
1370 sudo apt-get install ros-kinetic-ros-tutorials
1371 rosrun turtlesim turtlesim_node
1372 rosversion -d
1373 roscore
1374 roslaunch autoware_driveworks_gmsl_interface multi_gmsl.launch
1375 cd Autoware/ros/
1376 ./run
1377 roscore
1378 roslaunch autoware_driveworks_gmsl_interface multi_gmsl.launch
1379 cleaer
1380 clear
1381 roslaunch autoware_driveworks_gmsl_interface multi_gmsl.launch
1382 roslaunch multi_gmsl.launch
1383 source devel/setup.bash
1384 ./run
1385 Arg xml is <arg default="$(find autoware_driveworks_gmsl_interface)/calib/" name="cam_calib_folder"/>
1386 The traceback for the exception was written to the log file
1387 roslaunch autoware_driveworks_gmsl_interface multi_gmsl.launch
1388 exit
1389 source bashrc
1390 source
1391 source --help
1392 source -help
1393 sudo -s
1394 roslaunch autoware_driveworks_gmsl_interface multi_gmsl.launch
1395 roscd beginner_tutorials
1396 roslaunch turtlebot_gazebo turtlebot_world.launch
1397 roscore
1398 vi ~/.bashrc
1399 roscore
1400 cd Autoware/ros/
1401 ./run
1402 cd ..
1403 ls
1404 cd ..
1405 ls
1406 cd etc/
1407 ls
1408 cd apt
1409 ls
1410 vi sources.list
1411 vi sources.list.d
1412 cd Autoware/ros/
1413 cd install/
1414 ls
1415 source setup.bash
1416 cd ..
1417 ./run
1418 source install/setup.bash
1419 sudo ./run
1420 ls
1421 cd ..
1422 ls
1423 cd ..
1424 ls
1425 cd usr/
1426 ls
1427 cd bin/
1428 ls
1429 cd
1430 cd env
1431 vim env
1432 echo "source /opt/ros/kinetic/setup.bash" >> ~/.bashrc
1433 source ~/.bashrc
1434 rosrun turtlesim turtlesim_node
1435 source install/setup.bash
1436 ./run
1437 source install/local_setup.bash
1438 ./run
1439 source install/setup.bash
1440 roscd beginner_tutorials
1441 cd Autoware/ros/
1442 ls
1443 cd install/
1444 source setup.bash
1445 roscd beginner_tutorials
1446 cd ..
1447 roscd beginner_tutorials
1448 source install/setup.bash
1449 roscd beginner_tutorials
1450 ./run
1451 source install/local_setup.bash
1452 roscd beginner_tutorials
1453 rosrun rqt_console rqt_console
1454 sudo apt-get install ros-linetic-rqt ros-kinetic-rqt-common-plugins ros-kinetic-turtlesim
1455 sudo apt-get install ros-kinetic-rqt ros-kinetic-rqt-common-plugins ros-kinetic-turtlesim
1456 rosrun rqt_console rqt_console
1457 rosrun rqt_logger_level rqt_logger_level
1458 echo “source /opt/ros/kinetic/setup.bash” >> ~/.bashrc
1459 sudo source ~/.bashrc
1460 sudo -s source ~/.bashrc
1461 sudo -su source ~/.bashrc
1462 echo “source /opt/ros/kinetic/setup.bash” >> ~/.bashrc
1463 sudo -s source ~/.bashrc
1464 roscor
1465 roscore
1466 vi bashrc
1467 vi ~/.bashrc
1468 roscore
1469 vi ~/.bashrc
1470 echo “source /opt/ros/kinetic/setup.bash” >> ~/.bashrc
1471 echo “source /opt/ros/kinetic/setup.bash” >> ~/.bashrc
1472 echo “export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib:/usr/lib/aarch64-linux-gnu” >> ~/.bashrc
1473 source ~/.bashrc
1474 sudo -s source ~/.bashrc
1475 cd Autoware/ros/
1476 ./run
1477 source install/setup.bash
1478 ./run
1479 cd ~
1480 source
1481 echo “source /opt/ros/kinetic/setup.bash” >> ~/.bashrc
1482 source ~/.bashrc
1483 sudo -s source ~/.bashrc
1484 cd Autoware/ros/
1485 ./run
1486 vi ~/.bashrc
1487 roscore
1488 vi ~/.bashrc
1489 cd Autoware/ros/
1490 ./run
1491 roscore
1492 cd Autoware/ros/
1493 ./run
1494 vi ~/.bashrc
1495 source setup.bash
1496 roscd beginner_tutorials
1497 roscd beginner_tutorials
1498 source Autoware/ros/install/setup.bash
1499 roscd beginner_tutorials
1500 roscore
1501 catkin_make
1502 rosnode list
1503 rosnode ping my_turtle
1504 roslaunch multi_gmsl.launch
1505 roscore
1506 roslaunch usb_cam-test.launch
1507 roslaunch multi_gmsl.launch
1508 roslaunch usb_cam-test.launch
1509 roslaunch beginner_tutorials turtlemimic.launch
1510 roslaunch turtlemimic.launch
1511 udo apt-get install ros-kinetic-rqt ros-kinetic-rqt-common-plugins ros-kinetic-turtlesim
1512 sudo apt-get install ros-kinetic-rqt ros-kinetic-rqt-common-plugins ros-kinetic-turtlesim
1513 roscd autoware_driveworks_gmsl_interface
1514 cd Autoware/ros/
1515 ./run
1516 roslaunch gmsl_interface.launch
1517 source ~/.bashrc
1518 cd Autoware/ros/
1519 ./run
1520 roslaunch autoware_driveworks_gmsl_interface multi_gmsl.launch
1521 roslaunch gmsl_interface.launch
1522 roscore
1523 source setup.bash
1524 roslaunch autoware_driveworks_gmsl_interface multi_gmsl.launch
1525 vi ~/.bashrc
1526 source install/setup.bash
1527 roslaunch autoware_driveworks_gmsl_interface multi_gmsl.launch
1528 source install/local_setup.bash
1529 roslaunch autoware_driveworks_gmsl_interface multi_gmsl.launch
1530 roslaunch autoware_driveworks_gmsl_interface multi_gmsl.launch
1531 roslaunch turtle_tf turtle_tf_demo.launch
1532 vi ~/.profile
1533 roslaunch turtle_tf turtle_tf_demo.launch
1534 vi ~/.bashrc
1535 sudo -s echo “source /opt/ros/kinetic/setup.bash” >> ~/.bashrc
1536 source ~/.bashrc
1537 sduo -s source ~/.bashrc
1538 sudo -s source ~/.bashrc
1539 export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib:/usr/lib/aarch64-linux-gnu
1540 vi ~/.bashrc
1541 roslaunch turtle_tf turtle_tf_demo.launch
1542 roscore
1543 cd Autoware/ros/
1544 ./run
1545 sudo rosdep init
1546 rosdep
1547 roslaunch turtle_tf turtle_tf_demo.launch
1548 export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib:/usr/lib/aarch64-linux-gnu
1549 roslaunch turtle_tf turtle_tf_demo.launch
1550 echo $PATH
1551 sudo export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib:/usr/lib/aarch64-linux-gnu
1552 export
1553 export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib:/usr/lib/aarch64-linux-gnu
1554 export
1555 roslaunch turtle_tf turtle_tf_demo.launch
1556 roscore
1557 vi ~/.bash_profile
1558 vi ~/.profile
1559 vi ~/.bash_profile
1560 export
1561 echo $LD_LIBRARY_PATH
1562 vi ~/.bash_profile
1563 sudo ldconfig
1564 cd Autoware/ros/
1565 ./run
1566 cd Autoware/ros/
1567 ./run
1568 echo source /opt/ros/kinetic/setup.bash >> ~/.bashrc
1569 source ~/.bashrc
1570 roslaunch turtle_tf turtle_tf_demo.launch
1571 vi ~/.bashrc
1572 source ~/.bashrc
1573 roslaunch turtle_tf turtle_tf_demo.launch
1574 roscd log
1575 ls
1576 roslaunch turtle_tf turtle_tf_demo.launch
1577 roscd log
1578 cd ~
1579 roscd log
1580 roslaunch turtle_tf turtle_tf_demo.launch
1581 history
hi SteveNV
this issue has been solved, i re-install full ros. Thank u~
