Hello everyone!
I am facing trouble.
I have to use python3 because I am running TensorFlow 2.4.
My env is:
Jetson TX2, Jetpack 4.5, Python3, ROS melodic.
I want to publish the frame video from one node to other node so I have built vision_opencv inside the catkin_ws.
After runing catkin built I do not get any errors but when I ran in python3
from cv_bridge.boost.cv_bridge_boost import getCvType
I got this error
File "/home/jetson/catkin_ws/src/soka_drone/Scripts/test_opencv_2.py", line 104, in <module>
cam_test()
File "/home/jetson/catkin_ws/src/soka_drone/Scripts/test_opencv_2.py", line 87, in cam_test
msg = bridge.cv2_to_imgmsg(img, encoding="bgr8")
File "/home/jetson/catkin_ws/src/vision_opencv/cv_bridge/python/cv_bridge/core.py", line 263, in cv2_to_imgmsg
if self.cvtype_to_name[self.encoding_to_cvtype2(encoding)] != cv_type:
File "/home/jetson/catkin_ws/src/vision_opencv/cv_bridge/python/cv_bridge/core.py", line 91, in encoding_to_cvtype2
ModuleNotFoundError: No module named 'cv_bridge.boost.cv_bridge_boost'
This is how I built cv_bridge
sudo apt-get install python-catkin-tools python3-dev python3-catkin-pkg-modules python3-numpy python3-yaml ros-melodic-cv-bridge
# Create catkin workspace
mkdir catkin_ws
cd catkin_ws
catkin init
# Instruct catkin to set cmake variables
catkin config -DPYTHON_EXECUTABLE=/usr/bin/python3 -DPYTHON_INCLUDE_DIR=/usr/include/python3.6m -DPYTHON_LIBRARY=/usr/lib/aarch64-linux-gnu/libpython3.6m.so
# Instruct catkin to install built packages into install place. It is $CATKIN_WORKSPACE/install folder
catkin config --install
# Clone cv_bridge src
git clone https://github.com/ros-perception/vision_opencv.git src/vision_opencv
# Find version of cv_bridge in your repository
apt-cache show ros-melodic-cv-bridge | grep Version
cd src/vision_opencv/
git checkout 1.13.0
cd ../../
# Build
catkin build cv_bridge
# Extend environment with new package
source install/setup.bash --extend
Is there a way to install ROS noetic in Jetson TX2?
Hi @alberto18_90, I haven’t encountered this myself, but can you check your PYTHONPATH to make sure the cv_bridge module can be found? Can ROS find the cv_bridge package?
Are you able to import cv_bridge or is it just the extended from cv_bridge.boost.cv_bridge_boost import getCvType that gives error?
Dear @dusty_nv
Thank you for your reply.
Due to I am living in Japan I cannot answer right now but I am running the same project in my laptop and it is runing well (too slow, I realizeit’s because I don’t have GPU)
So I realize the problem is the path, can you send me the commands to setup correctly the paths of cv_bridge and python?
Thank you so much
Sorry, I’m not exactly familiar so you may need to play around with it. I believe ROS should automatically set the correct PYTHONPATH when your workspace overlay is sourced (hence my question about if ROS can find the cv_bridge package)
Also, after you source your workspace, try running:
@dusty_nv
Thank you for your help. I have been able to built the package by adding this two lines into catkin_ws/src/vision_opencv/cv_bridge/CMakeLists.txt
I am trying to publish the video I’m getting from the webcam and then subscribe from other ROS slaves and show the video in real-time. Is it possible to do that by using your ros_deep_learning node?
opencv_video → convert_image_to_other_format -->publish_msg. Is it correct this process?
