Hey. I experienced a lot of pain and suffering. I had difficulties with cross-compiling to my JTX1 R28.1 (Qt 5.9). I followed this instruction https://www.innovative-dsp.com/ftp/jetson/Configure%20Cross%20Compiling%20for%20Nvidia%20Jetson%20TX2%20on%20Ubuntu%2064%20bit.pdf.
The original script https://www.innovative-dsp.com/ftp/jetson/Host_Setup.sh did not work and I fixed it:
#!/bin/bash
#check for proper usage
if [ "$#" -ne 1 ]; then
echo "usage ./Host_Setup.sh IP_ADDRESS_OF_JETSON_DEVICE"
echo "example:"
echo "./Host_Setup.sh 192.168.0.101"
exit -1
fi
IP_ADDRESS=$1
#Install the GCC ARM toolset Linaro **VERSION 5
sudo apt-get install -y gcc-5-arm-linux-gnueabi g++-5-arm-linux-gnueabi
#create 64TX2 dir
cd $HOME && mkdir 64_TX2
mkdir 64_TX2/Linux_for_Tegra_tx2
mkdir 64_TX2/Linux_for_Tegra_tx2/rootfs
#Download GCC Linaro source
cd $HOME/64_TX2
sudo wget --no-check-certificate http://releases.linaro.org/components/toolchain/binaries/5.4-2017.05/aarch64-linux-gnu/gcc-linaro-5.4.1-2017.05-x86_64_aarch64-linux-gnu.tar.xz
sudo tar -xvf gcc-linaro-5.4.1-2017.05-x86_64_aarch64-linux-gnu.tar.xz
#Download Qt Source (Get at least Qt version 5.9.0)
cd $HOME
sudo wget --no-check-certificate http://download.qt.io/archive/qt/5.9/5.9.0/single/qt-everywhere-opensource-src-5.9.0.tar.xz
sudo tar -xvf qt-everywhere-opensource-src-5.9.0.tar.xz
#Install prerequisite Ubuntu packages for compiling Qt
sudo apt-get install -y 'libxcb.*' libx11-xcb-dev libglu1-mesa-dev libxrender-dev libxi-dev 'libinput*' 'mtdev*' mesa-utils mesa-utils-extra libgles2-mesa-dev
#Sync files from device back to host ROOTFS
cd $HOME/64_TX2/Linux_for_Tegra_tx2/rootfs
sudo rsync -e ssh -avz ubuntu@$IP_ADDRESS:/usr/include ./usr
sudo rsync -e ssh -avz ubuntu@$IP_ADDRESS:/usr/lib ./usr
#Fix Symbolic Links
cd $HOME
sudo wget --no-check-certificate https://www.innovative-dsp.com/ftp/jetson/fixsymlinks.sh
sudo chmod +x ./fixsymlinks.sh
sudo ./fixsymlinks.sh $HOME/64_TX2/Linux_for_Tegra_tx2/rootfs
#Configure Qt with these options
cd $HOME/qt-everywhere-opensource-src-5.9.0
./configure -opensource -release --confirm-license -device linux-jetson-tx1-g++ -device-option CROSS_COMPILE=$HOME/64_TX2/gcc-linaro-5.4.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu- -sysroot $HOME/64_TX2/Linux_for_Tegra_tx2/rootfs -nomake examples -nomake tests -prefix /usr/local/qt5 -extprefix $HOME/64_TX2/qt5 -hostprefix $HOME/64_TX2/qt5-host -opengl es2 -L /usr/lib/aarch64-linux-gnu -skip webkit -skip webview -skip webkit-examples
#Make Qt (the -j8 switch uses 8 CPU cores to do the build instead of the default 1 core)
make -j8
#Install Qt
sudo make install #Note: this will install the Qt build to /home/<USERNAME>/64_TX2/qt5-host
#Sync newly built Qt with Jetson device
cd $HOME/64_TX2/
sudo rsync -e ssh -avz qt5 ubuntu@$IP_ADDRESS:/usr/local
Line
prints an error:
Packages with unsatisfied dependencies:
libinput10-dbg: Depends: libinput10 (= 1.2.3-1ubuntu1) but 1.6.3-1ubuntu1 ~ 16.04.1 will be installed
E: It is impossible to fix errors, you have held broken packages.
I did not correct this error and continued the build phase. In the script https://www.innovative-dsp.com/ftp/jetson/Device_Setup.sh i change user:
#!/bin/bash
#Install Ubuntu packages
sudo apt-get install '.*libxcb.*' libxrender-dev libxi-dev libfontconfig1-dev libudev-dev
#Get GLES and EGL headers
mkdir /home/ubuntu/GLES
cd /home/ubuntu/GLES
apt-get download libgles2-mesa-dev
ar x libgles2*.deb
tar -xvf data.tar.xz
mkdir /home/ubuntu/EGL
cd /home/ubuntu/EGL
apt-get download libegl1-mesa-dev
ar x libegl1*.deb
#Copy headers to proper locations
cd /home/ubuntu/GLES/usr/include
sudo cp -r GLES2 GLES3 /usr/include
cd /home/ubuntu/EGL/usr/include
sudo cp -r EGL KHR /usr/include
#Setup symbolic link for libGLESv2
sudo ln -s /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv2.so.2 /usr/lib/aarch64-linux-gnu/libGLESv2.so
#Setup folder to copy built Qt to later
sudo mkdir /usr/local/qt5
sudo chown ubuntu /usr/local/qt5
#Show IP Address
echo Please note your IP address for rsync on the host
hostname -I
After entering
, an error occurs:
rsync: send_files failed to open “/usr/lib/cups/backend/serial”: Permission denied (13)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1655) [generator=3.1.1]
I did not correct this error and continued the build phase. After entering
, an error occurs:
/config.log
> /home/maksim/64_TX2/gcc-linaro-5.3.1-2016.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-g++ -Wl,-rpath-link,/home/maksim/64_TX2/Linux_for_Tegra_tx2/rootfs/usr/lib -Wl,-rpath-link,/home/maksim/64_TX2/Linux_for_Tegra_tx2/rootfs/usr/lib/aarch64-linux-gnu -Wl,-rpath-link,/home/maksim/64_TX2/Linux_for_Tegra_tx2/rootfs/usr/lib/aarch64-linux-gnu/tegra -Wl,-rpath-link,/home/maksim/64_TX2/Linux_for_Tegra_tx2/rootfs/lib/aarch64-linux-gnu --sysroot=/home/maksim/64_TX2/Linux_for_Tegra_tx2/rootfs -Wl,-O1 -fuse-ld=gold -o verifyspec verifyspec.o -L/home/maksim/64_TX2/Linux_for_Tegra_tx2/rootfs/usr/lib -L/home/maksim/64_TX2/Linux_for_Tegra_tx2/rootfs/lib/aarch64-linux-gnu -L/home/maksim/64_TX2/Linux_for_Tegra_tx2/rootfs/usr/lib/aarch64-linux-gnu -L/usr/lib/aarch64-linux-gnu
> /usr/bin/aarch64-linux-gnu-ld.gold: error: can not open /home/maksim/64_TX2/Linux_for_Tegra_tx2/rootfs/usr/lib/aarch64-linux-gnu/libm.so: no such file or directory
> /usr/bin/aarch64-linux-gnu-ld.gold: error: can not open /home/maksim/64_TX2/Linux_for_Tegra_tx2/rootfs/lib/aarch64-linux-gnu/libc.so.6: no such file or directory
> /usr/bin/aarch64-linux-gnu-ld.gold: error: can not open /home/maksim/64_TX2/Linux_for_Tegra_tx2/rootfs/lib/aarch64-linux-gnu/ld-linux-aarch64.so.1: no such file or directory
> /home/maksim/64_TX2/Linux_for_Tegra_tx2/rootfs/usr/lib/aarch64-linux-gnu/crt1.o(.text+0x24): error: undefined reference to '__libc_start_main'
> /home/maksim/64_TX2/Linux_for_Tegra_tx2/rootfs/usr/lib/aarch64-linux-gnu/crt1.o(.text+0x28): error: undefined reference to 'abort'
> collect2: error: ld returned 1 exit status
> Makefile: 67: failed to execute the recipe for the purpose of "verifyspec"
> make: *** [verifyspec] Error 1
I copied the directory /lib from the device to the host to directory $HOME/64_TX2/Linux_for_Tegra_tx2/rootfs/lib . Ok, continued the build phase! After entering
make -j8
, an error occurs:
.obj / qabstractsocket.o: qabstractsocket.cpp: function QAbstractSocketPrivate :: readFromSocket (): error: undefined reference to ‘QRingBuffer :: reserve (long long)’
.obj / qabstractsocket.o: qabstractsocket.cpp: function QAbstractSocketPrivate :: emitReadyRead (int): error: undefined reference to ‘QIODevice :: channelReadyRead (int)’
.obj / qabstractsocket.o: qabstractsocket.cpp: function QAbstractSocketPrivate :: emitBytesWritten (long long, int): error: undefined reference to ‘QIODevice :: channelBytesWritten (int, long long)’
.obj / qabstractsocket.o: qabstractsocket.cpp: function QAbstractSocket :: writeData (char const *, long long): error: undefined reference to ‘QRingBuffer :: append (char const *, long long)’
.obj / qabstractsocket.o: qabstractsocket.cpp: function QAbstractSocketPrivate :: fetchConnectionParameters (): error: undefined reference to ‘QIODevicePrivate :: setReadChannelCount (int)’
.obj / qabstractsocket.o: qabstractsocket.cpp: function QAbstractSocketPrivate :: writeToSocket (): error: undefined reference to ‘QRingBuffer :: free (long long)’
.obj / qsocks5socketengine.o: qsocks5socketengine.cpp: function QSocks5SocketEnginePrivate :: _ q_emitPendingReadNotification (): error: undefined reference to ‘QRingBuffer :: clear ()’
.obj / qsocks5socketengine.o: qsocks5socketengine.cpp: function QSocks5SocketEnginePrivate :: _ q_controlSocketError (QAbstractSocket :: SocketError): error: undefined reference to ‘QRingBuffer :: clear ()’
.obj / qsocks5socketengine.o: qsocks5socketengine.cpp: function QSocks5SocketEngine :: read (char *, long long): error: undefined reference to ‘QRingBuffer :: read (char *, long long)’
.obj / qnativesocketengine_unix.o: qnativesocketengine_unix.cpp: function QNativeSocketEnginePrivate :: nativeSelect (int, bool, bool, bool, bool *) const: error: undefined reference to ‘qt_safe_poll (pollfd *, unsigned long, timespec const *)’
.obj / qlocalsocket_unix.o: qlocalsocket_unix.cpp: function QLocalSocket :: waitForConnected (int): error: undefined reference to ‘qt_safe_poll (pollfd *, unsigned long, timespec const *)’
.obj / qlocalserver_unix.o: qlocalserver_unix.cpp: function QLocalServerPrivate :: waitForNewConnection (int, bool *): error: undefined reference to ‘qt_safe_poll (pollfd *, unsigned long, timespec const *)’
.obj / moc_qdnslookup_p.o: moc_qdnslookup_p.cpp: typeinfo for QDnsLookupRunnable: error: undefined reference to ‘typeinfo for QRunnable’
Makefile: 510: failed to execute the recipe for the target “…/…/lib/libQt5Network.so.5.9.0”
make [3]: *** […/…/lib/libQt5Network.so.5.9.0] Error 1
make [3]: exit the directory “/home/maksim/qt-everywhere-opensource-src-5.9.0/qtbase/src/network”
Makefile: 273: failed to execute the recipe for the “sub-network-make_first” target
make [2]: *** [sub-network-make_first] Error 2
make [2]: exit the “/home/maksim/qt-everywhere-opensource-src-5.9.0/qtbase/src” directory
Makefile: 49: failed to execute the recipe for the purpose of “sub-src-make_first”
make [1]: *** [sub-src-make_first] Error 2
make [1]: exit the “/home/maksim/qt-everywhere-opensource-src-5.9.0/qtbase” directory
Makefile: 82: failed to execute the recipe for the “module-qtbase-make_first” target
