I would like to crosscompile qt5 on TX2 but I can’t figure out how to do it. This is my first time working on a jetson and so I would appreciate it if you could provide me with as much detail as possible.
I have done the following:
I first tried the usual
sudo apt-get install qt5-default
and got the following:
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
qt5-default : Depends: qtbase5-dev but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
then I did :
sudo apt-get install qtbase5-dev
I got :
qtbase5-dev : Depends: libgles2-mesa-dev but it is not going to be installed or
libgles2-dev but it is not installable
Depends: libqt5core5a (= 5.5.1+dfsg-16ubuntu7) but 5.5.1+dfsg-16ubuntu7.1 is to be installed
Depends: libqt5dbus5 (= 5.5.1+dfsg-16ubuntu7) but 5.5.1+dfsg-16ubuntu7.1 is to be installed
Depends: libqt5gui5 (= 5.5.1+dfsg-16ubuntu7) but 5.5.1+dfsg-16ubuntu7.1 is to be installed
Depends: libqt5network5 (= 5.5.1+dfsg-16ubuntu7) but 5.5.1+dfsg-16ubuntu7.1 is to be installed
Depends: libqt5printsupport5 (= 5.5.1+dfsg-16ubuntu7) but 5.5.1+dfsg-16ubuntu7.1 is to be installed
Depends: libqt5sql5 (= 5.5.1+dfsg-16ubuntu7) but 5.5.1+dfsg-16ubuntu7.1 is to be installed
Depends: libqt5test5 (= 5.5.1+dfsg-16ubuntu7) but 5.5.1+dfsg-16ubuntu7.1 is to be installed
Depends: libqt5widgets5 (= 5.5.1+dfsg-16ubuntu7) but 5.5.1+dfsg-16ubuntu7.1 is to be installed
Depends: libqt5xml5 (= 5.5.1+dfsg-16ubuntu7) but 5.5.1+dfsg-16ubuntu7.1 is to be installed
Recommends: libqt5opengl5-dev (= 5.5.1+dfsg-16ubuntu7) but it is not going to be installed
I kept going down the rabbit hole and I kept seeing something similar to this:
libqt5opengl5 is already the newest version (5.5.1+dfsg-16ubuntu7.1).
libqt5opengl5 set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 11 not upgraded.
for most of the ones I tried
then I saw the post :
https://devtalk.nvidia.com/default/topic/1031227/jetson-tx2/qt5-on-r28-2/post/5246271/#5246271
I followed it and the output of
sudo apt-get install qtbase5-dev qtbase5-dev-tools
is :
then I entered:
sha1sum -c /etc/nv_tegra_release
got :
/usr/lib/aarch64-linux-gnu/tegra/libnvosd.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_image.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvomx.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvmedia.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_utils.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libglx.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libscf.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvexif.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvrm_gpu.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvtx_helper.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvfnetstorehdfx.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvmm_parser.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvrm.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvmm_contentpipe.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvos.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvtnr.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvimp.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvfnet.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvavp.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_video.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvfnetstoredefog.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvodm_imager.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvjpeg.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvtvmr.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvidia-egl-wayland.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvdc.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libtegrav4l2.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvmm.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvapputil.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvcameratools.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvcam_imageencoder.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnveglstream_camconsumer.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvmm_utils.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvomxilclient.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libargus.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvwinsys.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libargus_socketclient.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnveglstreamproducer.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvll.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libargus_socketserver.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvrm_graphics.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvcolorutil.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvddk_2d_v2.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvtestresults.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvcamerautils.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvcamlog.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvparser.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvddk_vic.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvmmlite.so: OK
/usr/lib/aarch64-linux-gnu/libv4l/plugins/libv4l2_nvvidconv.so: OK
/usr/lib/aarch64-linux-gnu/libv4l/plugins/libv4l2_nvvideocodec.so: OK
/usr/lib/xorg/modules/drivers/nvidia_drv.so: OK
/usr/lib/xorg/modules/extensions/libglx.so: OK
I modified the
/etc/apt/sources.list
as well
I also tried compiling qt5 from source, I got no errors but when I opened the application let’s just say it was a page of empty buttons on a white page :D
I googled alot but no lock.
can anyone help me get this working?
Thank you in advance
