Thanks Dustin,
Now it is not tk1 but tx2.
Do we have an equivalent of
sudo apt-get install build-essential qt5-default qtcreator -y
or rather should be looking for a compiling from source for being able to program with qt\qtcreator?
Andrey
Yes, these packages are available on TX2.
Really?
could you share your sources.list in case your execution of the command above succeeds, please?
In my case that returns : only the package qtchooser available
Doing:
git clone https://github.com/qt/qt5
cd qt5
./init-repository
You may have to enable multiverse [EDIT: in fact universe is required, not multiverse] :
deb http://ports.ubuntu.com/ubuntu-ports/ xenial main restricted universe multiverse
deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial main restricted universe multiverse
deb http://ports.ubuntu.com/ubuntu-ports/ xenial-updates main restricted universe multiverse
deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial-updates main restricted universe multiverse
deb http://ports.ubuntu.com/ubuntu-ports/ xenial-security main restricted universe multiverse
deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial-security main restricted universe multiverse
I had build-essential already installed :
sudo apt search build-essential
build-essential/xenial,now 12.1ubuntu2 arm64 [installed]
Informational list of build-essential packages
I have installed for being sure (had just checked with apt search till now) :
sudo apt-get install qt5-default
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
qt5-default
0 upgraded, 1 newly installed, 0 to remove and 12 not upgraded.
Need to get 16.5 kB of archives.
After this operation, 100 kB of additional disk space will be used.
Get:1 http://ports.ubuntu.com/ubuntu-ports xenial-updates/universe arm64 qt5-default arm64 5.5.1+dfsg-16ubuntu7.2 [16.5 kB]
Fetched 16.5 kB in 0s (58.7 kB/s)
Selecting previously unselected package qt5-default:arm64.
(Reading database ... 185866 files and directories currently installed.)
Preparing to unpack .../qt5-default_5.5.1+dfsg-16ubuntu7.2_arm64.deb ...
Unpacking qt5-default:arm64 (5.5.1+dfsg-16ubuntu7.2) ...
Setting up qt5-default:arm64 (5.5.1+dfsg-16ubuntu7.2) ...
sudo apt-get install qtcreator
The following additional packages will be installed:
libbotan-1.10-1 libclang1-3.6 libllvm3.6v5 libobjc-5-dev libobjc4 libqbscore1 libqbsqtprofilesetup1
libqt5clucene5 libqt5designer5 libqt5designercomponents5 libqt5help5 libqt5quickwidgets5 libqt5script5
libqt5xmlpatterns5 qml-module-qtquick-controls qtcreator-data qtcreator-doc qttools5-dev-tools
qtxmlpatterns5-dev-tools
Suggested packages:
kdelibs5-data subversion ubuntu-sdk qt5-doc
libqt5xmlpatterns5 qml-module-qtquick-controls qtcreator qtcreator-data qtcreator-doc qttools5-dev-tools
0 upgraded, 20 newly installed, 0 to remove and 12 not upgraded.
Need to get 38.2 MB of archives.
After this operation, 140 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://ports.ubuntu.com/ubuntu-ports xenial/universe arm64 libqt5script5 arm64 5.5.1+dfsg-2build1 [470 kB]
Get:2 http://ports.ubuntu.com/ubuntu-ports xenial/main arm64 qml-module-qtquick-controls arm64 5.5.1-1ubuntu1 [621 kB]
Get:3 http://ports.ubuntu.com/ubuntu-ports xenial/universe arm64 libbotan-1.10-1 arm64 1.10.12-1 [888 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports xenial/main arm64 libllvm3.6v5 arm64 1:3.6.2-3ubuntu2 [6,809 kB]
Get:5 http://ports.ubuntu.com/ubuntu-ports xenial-updates/main arm64 libobjc4 arm64 5.4.0-6ubuntu1~16.04.4 [35.4 kB]
Get:6 http://ports.ubuntu.com/ubuntu-ports xenial-updates/main arm64 libobjc-5-dev arm64 5.4.0-6ubuntu1~16.04.4 [172 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports xenial/main arm64 libclang1-3.6 arm64 1:3.6.2-3ubuntu2 [3,028 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports xenial/universe arm64 libqbscore1 arm64 1.4.5+dfsg-2 [643 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports xenial/universe arm64 libqbsqtprofilesetup1 arm64 1.4.5+dfsg-2 [45.9 kB]
Get:10 http://ports.ubuntu.com/ubuntu-ports xenial/universe arm64 libqt5clucene5 arm64 5.5.1-3build1 [246 kB]
Get:11 http://ports.ubuntu.com/ubuntu-ports xenial/universe arm64 libqt5designer5 arm64 5.5.1-3build1 [2,586 kB]
Get:12 http://ports.ubuntu.com/ubuntu-ports xenial/universe arm64 libqt5designercomponents5 arm64 5.5.1-3build1 [570 kB]
Get:13 http://ports.ubuntu.com/ubuntu-ports xenial/universe arm64 libqt5help5 arm64 5.5.1-3build1 [163 kB]
Get:14 http://ports.ubuntu.com/ubuntu-ports xenial/main arm64 libqt5quickwidgets5 arm64 5.5.1-2ubuntu6 [27.5 kB]
Get:15 http://ports.ubuntu.com/ubuntu-ports xenial/main arm64 libqt5xmlpatterns5 arm64 5.5.1-2build1 [850 kB]
Get:16 http://ports.ubuntu.com/ubuntu-ports xenial/universe arm64 qtcreator-data all 3.5.1+dfsg-2ubuntu2 [2,134 kB]
Get:17 http://ports.ubuntu.com/ubuntu-ports xenial/universe arm64 qtcreator arm64 3.5.1+dfsg-2ubuntu2 [10.6 MB]
Get:18 http://ports.ubuntu.com/ubuntu-ports xenial/universe arm64 qtcreator-doc all 3.5.1+dfsg-2ubuntu2 [6,770 kB]
Get:19 http://ports.ubuntu.com/ubuntu-ports xenial/universe arm64 qttools5-dev-tools arm64 5.5.1-3build1 [1,476 kB]
Get:20 http://ports.ubuntu.com/ubuntu-ports xenial/universe arm64 qtxmlpatterns5-dev-tools arm64 5.5.1-2build1 [22.5 kB]
Fetched 38.2 MB in 2min 28s (258 kB/s)
Selecting previously unselected package libqt5script5:arm64.
(Reading database ... 185871 files and directories currently installed.)
Preparing to unpack .../libqt5script5_5.5.1+dfsg-2build1_arm64.deb ...
Unpacking libqt5script5:arm64 (5.5.1+dfsg-2build1) ...
Selecting previously unselected package qml-module-qtquick-controls:arm64.
Preparing to unpack .../qml-module-qtquick-controls_5.5.1-1ubuntu1_arm64.deb ...
Unpacking qml-module-qtquick-controls:arm64 (5.5.1-1ubuntu1) ...
Selecting previously unselected package libbotan-1.10-1.
Preparing to unpack .../libbotan-1.10-1_1.10.12-1_arm64.deb ...
Unpacking libbotan-1.10-1 (1.10.12-1) ...
Selecting previously unselected package libllvm3.6v5:arm64.
Preparing to unpack .../libllvm3.6v5_1%3a3.6.2-3ubuntu2_arm64.deb ...
Unpacking libllvm3.6v5:arm64 (1:3.6.2-3ubuntu2) ...
Selecting previously unselected package libobjc4:arm64.
Preparing to unpack .../libobjc4_5.4.0-6ubuntu1~16.04.4_arm64.deb ...
Unpacking libobjc4:arm64 (5.4.0-6ubuntu1~16.04.4) ...
Selecting previously unselected package libobjc-5-dev:arm64.
Preparing to unpack .../libobjc-5-dev_5.4.0-6ubuntu1~16.04.4_arm64.deb ...
Unpacking libobjc-5-dev:arm64 (5.4.0-6ubuntu1~16.04.4) ...
Selecting previously unselected package libclang1-3.6:arm64.
Preparing to unpack .../libclang1-3.6_1%3a3.6.2-3ubuntu2_arm64.deb ...
Unpacking libclang1-3.6:arm64 (1:3.6.2-3ubuntu2) ...
Selecting previously unselected package libqbscore1.
Preparing to unpack .../libqbscore1_1.4.5+dfsg-2_arm64.deb ...
Unpacking libqbscore1 (1.4.5+dfsg-2) ...
Selecting previously unselected package libqbsqtprofilesetup1.
Preparing to unpack .../libqbsqtprofilesetup1_1.4.5+dfsg-2_arm64.deb ...
Unpacking libqbsqtprofilesetup1 (1.4.5+dfsg-2) ...
Selecting previously unselected package libqt5clucene5:arm64.
Preparing to unpack .../libqt5clucene5_5.5.1-3build1_arm64.deb ...
Unpacking libqt5clucene5:arm64 (5.5.1-3build1) ...
Selecting previously unselected package libqt5designer5:arm64.
Preparing to unpack .../libqt5designer5_5.5.1-3build1_arm64.deb ...
Unpacking libqt5designer5:arm64 (5.5.1-3build1) ...
Selecting previously unselected package libqt5designercomponents5:arm64.
Preparing to unpack .../libqt5designercomponents5_5.5.1-3build1_arm64.deb ...
Unpacking libqt5designercomponents5:arm64 (5.5.1-3build1) ...
Selecting previously unselected package libqt5help5:arm64.
Preparing to unpack .../libqt5help5_5.5.1-3build1_arm64.deb ...
Unpacking libqt5help5:arm64 (5.5.1-3build1) ...
Selecting previously unselected package libqt5quickwidgets5:arm64.
Preparing to unpack .../libqt5quickwidgets5_5.5.1-2ubuntu6_arm64.deb ...
Unpacking libqt5quickwidgets5:arm64 (5.5.1-2ubuntu6) ...
Selecting previously unselected package libqt5xmlpatterns5:arm64.
Preparing to unpack .../libqt5xmlpatterns5_5.5.1-2build1_arm64.deb ...
Unpacking libqt5xmlpatterns5:arm64 (5.5.1-2build1) ...
Selecting previously unselected package qtcreator-data.
Preparing to unpack .../qtcreator-data_3.5.1+dfsg-2ubuntu2_all.deb ...
Unpacking qtcreator-data (3.5.1+dfsg-2ubuntu2) ...
Selecting previously unselected package qtcreator.
Preparing to unpack .../qtcreator_3.5.1+dfsg-2ubuntu2_arm64.deb ...
Unpacking qtcreator (3.5.1+dfsg-2ubuntu2) ...
Selecting previously unselected package qtcreator-doc.
Preparing to unpack .../qtcreator-doc_3.5.1+dfsg-2ubuntu2_all.deb ...
Unpacking qtcreator-doc (3.5.1+dfsg-2ubuntu2) ...
Selecting previously unselected package qttools5-dev-tools.
Preparing to unpack .../qttools5-dev-tools_5.5.1-3build1_arm64.deb ...
Unpacking qttools5-dev-tools (5.5.1-3build1) ...
Selecting previously unselected package qtxmlpatterns5-dev-tools.
Preparing to unpack .../qtxmlpatterns5-dev-tools_5.5.1-2build1_arm64.deb ...
Unpacking qtxmlpatterns5-dev-tools (5.5.1-2build1) ...
Processing triggers for libc-bin (2.23-0ubuntu7) ...
Processing triggers for ccache (3.2.4-1) ...
Updating symlinks in /usr/lib/ccache ...
Processing triggers for hicolor-icon-theme (0.15-0ubuntu1) ...
Processing triggers for shared-mime-info (1.5-2ubuntu0.1) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu5.1) ...
Processing triggers for gnome-menus (3.13.3-6ubuntu3.1) ...
Processing triggers for bamfdaemon (0.5.3~bzr0+16.04.20160824-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for mime-support (3.59ubuntu1) ...
Processing triggers for man-db (2.7.5-1) ...
Setting up libqt5script5:arm64 (5.5.1+dfsg-2build1) ...
Setting up qml-module-qtquick-controls:arm64 (5.5.1-1ubuntu1) ...
Setting up libbotan-1.10-1 (1.10.12-1) ...
Setting up libllvm3.6v5:arm64 (1:3.6.2-3ubuntu2) ...
Setting up libobjc4:arm64 (5.4.0-6ubuntu1~16.04.4) ...
Setting up libobjc-5-dev:arm64 (5.4.0-6ubuntu1~16.04.4) ...
Setting up libclang1-3.6:arm64 (1:3.6.2-3ubuntu2) ...
Setting up libqbscore1 (1.4.5+dfsg-2) ...
Setting up libqbsqtprofilesetup1 (1.4.5+dfsg-2) ...
Setting up libqt5clucene5:arm64 (5.5.1-3build1) ...
Setting up libqt5designer5:arm64 (5.5.1-3build1) ...
Setting up libqt5designercomponents5:arm64 (5.5.1-3build1) ...
Setting up libqt5help5:arm64 (5.5.1-3build1) ...
Setting up libqt5quickwidgets5:arm64 (5.5.1-2ubuntu6) ...
Setting up libqt5xmlpatterns5:arm64 (5.5.1-2build1) ...
Setting up qtcreator-data (3.5.1+dfsg-2ubuntu2) ...
Setting up qtcreator (3.5.1+dfsg-2ubuntu2) ...
Setting up qtcreator-doc (3.5.1+dfsg-2ubuntu2) ...
Setting up qttools5-dev-tools (5.5.1-3build1) ...
Setting up qtxmlpatterns5-dev-tools (5.5.1-2build1) ...
I would never guess to turn on universe multiverse!
Thanks a lot!
