Hi All!
I’m new to CUDA and to get warmed up I have been playing with some example code that uses multi-dimensional arrays. The original code used integers, I changed these to floats so that I could play around with basic maths functions. If I run the code below I get some weird rounding. Each number in the array should have a value that ends in .55, and when printed to 1 decimal place should round up to .6. However when I actually run the code, the first group of numbers rounds to .6 - the following 3 groups round to .5 - and then the remaining groups round to .6.
Can anyone explain why this is? Am I doing something wrong?
The program is running on a Quadro FX 570 (Compute 1.1), windows vista (32bit), and compiled in MSVC++ 2010 express.
Here is the code:
#include <stdlib.h>
#include <stdio.h>
global void kernel(float *array)
int index_x = blockIdx.x * blockDim.x + threadIdx.x;
int index_y = blockIdx.y * blockDim.y + threadIdx.y;
// map the two 2D indices to a single linear, 1D index
int grid_width = gridDim.x * blockDim.x;
int index = index_y * grid_width + index_x;
// map the two 2D block indices to a single linear, 1D block index
float result = blockIdx.y * gridDim.x + blockIdx.x + 0.55; // each value will end in .55
// write out the result
array[index] = result;
int main(void)
int num_elements_x = 16;
int num_elements_y = 16;
int num_bytes = num_elements_x * num_elements_y * sizeof(int);
float *device_array = 0;
float *host_array = 0;
// allocate memory in either space
host_array = (float*)malloc(num_bytes);
cudaMalloc((void**)&device_array, num_bytes);
// create two dimensional 4x4 thread blocks
dim3 block_size;
block_size.x = 4;
block_size.y = 4;
// configure a two dimensional grid as well
dim3 grid_size;
grid_size.x = num_elements_x / block_size.x;
grid_size.y = num_elements_y / block_size.y;
// grid_size & block_size are passed as arguments to the triple chevrons as usual
kernel<<<grid_size,block_size>>>(device_array);
// download and inspect the result on the host:
cudaMemcpy(host_array, device_array, num_bytes, cudaMemcpyDeviceToHost);
// print out the result element by element
for(int row = 0; row < num_elements_y; ++row)
for(int col = 0; col < num_elements_x; ++col)
printf("%2.1f ", host_array[row * num_elements_x + col]);
printf("\n");
printf("\n");
// deallocate memory
free(host_array);
cudaFree(device_array);
getchar();
