anath
December 8, 2023, 10:02pm
1
Ref:
https://docs.nvidia.com/jetson/archives/r36.2/DeveloperGuide/SD/Kernel/KernelCustomization.html
Board:
AGX Orin Dev board
Steps done so far,
Flashed JP6 to NVME using ./flash script to Orin without any tools.
Host Side:
Followed the reference guide above.
How do I fix this and how do I apply this modified kernel to the jetson finally ?
DaveYYY
December 11, 2023, 1:27am
3
Did you remember to do this when building kernel modules?
export IGNORE_PREEMPT_RT_PRESENCE=1
anath
December 11, 2023, 12:37pm
4
@DaveYYY I think I did but I will do it again, but I am still unclear on the flashing issue after building the RT kernel, can you please provide some steps. Documentation is not complete or not very clear and this issue has been opened by everyone for every jetpack release,
After following the manual on the host side, do I need to install the jetpack 6 first on the jetson, so these kernal specific files can be copied over to the folder which sdkmanager uses ?
Nvidia Jetson Linux Real-Time Ke_e3be6c1c0e974075b8eae394d79957b5-081223-0958-2.pdf (9.9 KB)
Is the process similar to Jetpack 5 ?
DaveYYY
December 11, 2023, 1:05pm
5
I don’t know what you are talking about here.
If you are building your own kernel, then you should use flashing scripts to flash your device, instead of SDK Manager.
NO. They are not the same.
Please refer to our document specific for 36.2.
anath
December 11, 2023, 1:07pm
6
@DaveYYY I have seen in regular flash with JP6, issue with joystick. How can I make sure while building kernel that CONFIG_LOGITECH_FF is enabled ?
Is there any documentation on this ?
DaveYYY
December 11, 2023, 1:13pm
7
You can simply modify Linux_for_Tegra/source/kernel/kernel-jammy-src/arch/arm64/configs/defconfig to add the kernel config you want.
I think kernel config is not documented because it’s like a basic thing in kernel world.
anath
December 11, 2023, 3:12pm
8
anath:
CONFIG_LOGITECH_FF
@DaveYYY I am getting this error, on building out of Nvidia tree modules.
I see the modules are in /rootfs/usr/src/nvidia
DaveYYY
December 11, 2023, 3:19pm
9
Did you extract all the source tarballs?
$ cd <install-path>/Linux_for_Tegra/source
$ tar xf kernel_src.tbz2
$ tar xf kernel_oot_modules_src.tbz2
$ tar xf nvidia_kernel_display_driver_source.tbz2
anath
December 11, 2023, 3:20pm
10
Yes, I had done that in beginning, but I do not see it anymore. Its weird
DaveYYY
December 11, 2023, 3:21pm
11
Please delete the whole BSP folder and try again by closely following the guide.
I just built the same customized RT kernel today, and there was no issue.
anath
December 11, 2023, 3:25pm
13
It is in the right folder (all the source tarballs), my bad. Wrong folder screenshot I took above
DaveYYY
December 11, 2023, 3:27pm
14
Ideally, you should have all these stuff under Linux_for_Tegra/source/
argus_cam_libavencoder_src.tbz2
argus_cam_libavencoder_src.tbz2.sha1sum
atf_src.tbz2
atf_src.tbz2.sha1sum
dtc-1.4.5.tbz2
dtc-1.4.5.tbz2.sha1sum
generic_rt_build.sh
gstegl_src.tbz2
gstegl_src.tbz2.sha1sum
gstjpeg_src.tbz2
gstjpeg_src.tbz2.sha1sum
gst-nvarguscamera_src.tbz2
gst-nvarguscamera_src.tbz2.sha1sum
gst-nvcompositor_src.tbz2
gst-nvcompositor_src.tbz2.sha1sum
gst-nvtee_src.tbz2
gst-nvtee_src.tbz2.sha1sum
gst-nvv4l2camera_src.tbz2
gst-nvv4l2camera_src.tbz2.sha1sum
gst-nvvidconv_src.tbz2
gst-nvvidconv_src.tbz2.sha1sum
gst-nvvideo4linux2_src.tbz2
gst-nvvideo4linux2_src.tbz2.sha1sum
hardware
hwpm
kernel
kernel_oot_modules_src.tbz2.sha1sum
kernel_src_build_env.sh
kernel_src.tbz2
kernel_src.tbz2.sha1sum
libgstnvcustomhelper_src.tbz2
libgstnvcustomhelper_src.tbz2.sha1sum
libgstnvdrmvideosink_src.tbz2
libgstnvdrmvideosink_src.tbz2.sha1sum
libgstnvvideosinks_src.tbz2
libgstnvvideosinks_src.tbz2.sha1sum
libv4l2_nvargus_src.tbz2
libv4l2_nvargus_src.tbz2.sha1sum
Makefile
nvbuild.sh
nvcommon_build.sh
nvdisplay
nvethernetrm
nvgpu
nvgstapps_src.tbz2
nvgstapps_src.tbz2.sha1sum
nvidia-jetson-optee-source.tbz2
nvidia-jetson-optee-source.tbz2.sha1sum
nvidia_kernel_display_driver_source.tbz2.sha1sum
nvidia_kernel_display_driver_source_without_root_dir.tbz2
nvidia_kernel_display_driver_source_without_root_dir.tbz2.sha1sum
nvidia-oot
nvidia-xconfig_src.tbz2
nvidia-xconfig_src.tbz2.sha1sum
nv_public_src_build.sh
nv_public_src_build_tos.sh
nvsample_cudaprocess_src.tbz2
nvsample_cudaprocess_src.tbz2.sha1sum
nvsci_headers.tbz2
nvsci_headers.tbz2.sha1sum
nvsci_samples_src.tbz2
nvsci_samples_src.tbz2.sha1sum
nv_src_build.sh
opencv_gst_samples_src.tbz2
opencv_gst_samples_src.tbz2.sha1sum
openwfd_headers.tbz2
openwfd_headers.tbz2.sha1sum
out
public_sources_sha.txt
source_sync.sh
spe-freertos-bsp.tbz2
spe-freertos-bsp.tbz2.sha1sum
v4l2_libs_src.tbz2
v4l2_libs_src.tbz2.sha1sum
anath
December 11, 2023, 3:31pm
15
Under Linux_for_Tegra/source/
under out it does not match
I definitely had followed the manual closely with clearing my entire VM and then re-start fresh install.
DaveYYY
December 11, 2023, 3:35pm
16
So what’s the error now?
Can you please give the log as text here? Screenshots are not preferred.
anath
December 11, 2023, 3:36pm
17
make[1]: Leaving directory '/home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/source/kernel/kernel-jammy-src'
if [ ! -d "/home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/source/nvgpu" ] ; then \
echo "Directory nvgpu is not found, exiting.."; \
false; \
fi
make modules_install - nvgpu ...
make -j 2 ARCH=arm64 \
-C /home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/source/kernel/kernel-jammy-src \
M=/home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/source/nvgpu/drivers/gpu/nvgpu \
CONFIG_TEGRA_OOT_MODULE=m \
srctree.nvidia=/home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/source/nvidia-oot \
srctree.nvidia-oot=/home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/source/nvidia-oot \
srctree.nvconftest=/home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/source/out/nvidia-conftest \
KBUILD_EXTRA_SYMBOLS=/home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/source/nvidia-oot/Module.symvers \
modules_install
make[1]: Entering directory '/home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/source/kernel/kernel-jammy-src'
INSTALL /home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/rootfs//lib/modules/5.15.122-rt-tegra/extra/nvgpu.ko
SIGN /home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/rootfs//lib/modules/5.15.122-rt-tegra/extra/nvgpu.ko
DEPMOD /home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/rootfs//lib/modules/5.15.122-rt-tegra
make modules_install - nvidia-display ...
make -C /home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/source/out/nvidia-linux-header \
M=/home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/source/nvdisplay/kernel-open modules_install
make[1]: Entering directory '/home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/source/out/nvidia-linux-header'
INSTALL /home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/rootfs//lib/modules/5.15.122-rt-tegra/extra/nvidia-drm.ko
SIGN /home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/rootfs//lib/modules/5.15.122-rt-tegra/extra/nvidia-drm.ko
INSTALL /home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/rootfs//lib/modules/5.15.122-rt-tegra/extra/nvidia-modeset.ko
SIGN /home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/rootfs//lib/modules/5.15.122-rt-tegra/extra/nvidia-modeset.ko
INSTALL /home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/rootfs//lib/modules/5.15.122-rt-tegra/extra/nvidia.ko
SIGN /home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/rootfs//lib/modules/5.15.122-rt-tegra/extra/nvidia.ko
make[1]: Leaving directory '/home/jetson/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/source/out/nvidia-linux-header'
Is this error or looks good to you ?
DaveYYY
December 11, 2023, 3:38pm
18
I don’t feel like it’s error at all.
It looks fine.
If it’s indeed error, then compilation would just stop, so if it does not stop, then everything is fine.
anath
December 11, 2023, 3:39pm
19
Ok just wanted to confirm, thank you I will keep going with the process.
anath
December 11, 2023, 4:22pm
21
@DaveYYY I finished the flash but its stuck on boot screen as below, any thoughts or shall I try to re-flash ?
Flash command used :
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_nvme.xml -S 500GiB --showlogs --erase-all jetson-agx-orin-devkit nvme0n1p
flash_log.txt (63.5 KB)
DaveYYY
December 11, 2023, 4:32pm
22
Dump the serial console log, please.
The screenshot and flashing log do not give any useful information.
anath
December 11, 2023, 5:07pm
23
As per this it did not find nvme0n1p1 root device but found it couple lines above.
In the end I tried different variations, flashing in mmcblk01 by removing SSD card, tried flashing nvme0n1p2 but no luck. Please let me know your thoughts, unless this would be strange if adding "CONFIG_LOGITECH_FF " is causing the issue.
