Strange behavior of rtPrintf while compilation
- Error
int q = primIdx;
rtPrintf("i=%d p0 %f %f %f, p1 %f %f %f, p2 %f %f %f, n %f %f %f\n", q,
//rtPrintf("p0 %f %f %f, p1 %f %f %f, p2 %f %f %f, n %f %f %f\n",
p0.x, p0.y, p0.z,
p1.x, p1.y, p1.z,
p2.x, p2.y, p2.z,
n.x, n.y, n.z);
>CustomBuild:
1> Building NVCC ptx file lib/ptx/iso_trg_generated_triangle_mesh_small.cu.ptx
1>D:/CUDA_OPTIX/OptiX SDK 3.5.1/iso_trg/iso_trg/triangle_mesh_small.cu(56): error : no instance of overloaded function "rtPrintf" matches the argument list
1> argument types are: (const char [56], int, float, float, float, float, float, float, float, float, float, float, float, float)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
- Good
int q = primIdx;
//rtPrintf("i=%d p0 %f %f %f, p1 %f %f %f, p2 %f %f %f, n %f %f %f\n", q,
p0.x, p0.y, p0.z,
p1.x, p1.y, p1.z,
p2.x, p2.y, p2.z,
n.x, n.y, n.z);
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
- Error
rtPrintf("i=%d %d p0 %f %f %f, p1 %f %f %f, p2 %f %f %f, n %f %f %f\n", q, q,
p0.x, p0.y, p0.z,
p1.x, p1.y, p1.z,
p2.x, p2.y, p2.z,
n.x, n.y, n.z);
- Good
int q = primIdx;
rtPrintf("i=%d %d p1 %f %f %f, p2 %f %f %f, n %f %f %f \n", q, q,
//p0.x, p0.y, p0.z,
p1.x, p1.y, p1.z,
p2.x, p2.y, p2.z,
n.x, n.y, n.z);
- Good
int q = primIdx;
rtPrintf("i=%d ", q);
//rtPrintf("i=%d %d p1 %f %f %f, p2 %f %f %f, n %f %f %f \n", q, q,
p0.x, p0.y, p0.z,
p1.x, p1.y, p1.z,
p2.x, p2.y, p2.z,
n.x, n.y, n.z);
Win 8.1, x64, VS2010, OptiX 3.5.1, CUDA 5.5, GeForce GTX 650 ti.
