I am running deepstream application (default resnet-10 model) using RTSP. The frame rate is considerably low while processing RTSP streams compared to when files are processed. The fps is around 9-10 fps.
I am using HIKVision IP Cameras Model : DS-2CD202WF-I . I also get the following warning and sometimes the app crashes.
Warning -
WARNING from depay_elem0: Could not decode stream.
Debug info: gstrtph264depay.c(1259): gst_rtp_h264_depay_process (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstRtpH264Depay:depay_elem0:
Undefined packet type
Crash -
ERROR from depay_elem1: The stream is in the wrong format.
Debug info: gstrtph264depay.c(1270): gst_rtp_h264_depay_process (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin1/GstRtpH264Depay:depay_elem1:
NAL unit type 27 not supported yet
Quitting
App run failed
Do you run your case cased on source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt? Parameters in this config file is tuned for Jetson Nano.
