Rtspsrc cannot read some streams
• Nvidia 3060
• DeepStream Version 6.3
• Bugs
• Working from deepstream container
I’ve implemented a simple pipeline to read an rtsp stream with rtspsrc element and display it in a window.
However, for some streams, I’m getting an error and the pipeline seems to be blocked. Could you suggest some solutions?
Here are the code and logs :
CODE
import gi
gi.require_version("Gst", "1.0")
from gi.repository import Gst, GObject
import threading
import time
import sys
def cb_newpad(element, element_src_pad, data):
	print("IN NEW PAD")
	caps = element_src_pad.get_current_caps()
	structure = caps.get_structure(0)
	name = structure.get_name()
	media_type = structure.get_value("media")
	print(f"Pad added: {media_type} & {name}")
	if media_type == "video" and name == "application/x-rtp":
		print("Here we go")
		sinkpad = data.get_static_pad("sink") #where data is depay element
		print("Source pad capabilities:", element_src_pad.query_caps(None).to_string())
		print("Sink pad capabilities:", sinkpad.query_caps(None).to_string())
		if element_src_pad.link(sinkpad)  != Gst.PadLinkReturn.OK:
			print('Elements could not be linked: 1. Exiting.', flush=True)
			sys.exit(-1)
def on_error(bus, message):
	err, debug = message.parse_error()
	print(f"Error: {err}, {debug}")
def main():
	GObject.threads_init()
	Gst.init(None)
	# Set the default debug threshold
	Gst.debug_set_default_threshold(3)
	pipeline = Gst.Pipeline.new("dstest-sr-pipeline")
	source = Gst.ElementFactory.make("rtspsrc", "rtsp-source")
	source.set_property("location", "rtsp://x.x.x.x/onvif-media/media.amp")
	depay_pre_decode = Gst.ElementFactory.make("rtph264depay", "h264-depay")
	parse = Gst.ElementFactory.make("h264parse", "parse")
	source.connect("pad-added", cb_newpad, depay_pre_decode)
	decoder = Gst.ElementFactory.make("nvv4l2decoder", "nvv4l2-decoder")
	convert = Gst.ElementFactory.make("nvvideoconvert", "convert")
	caps = Gst.Caps.from_string("video/x-raw,width=1920,height=1080,formate=I420")
	filter = Gst.ElementFactory.make("capsfilter", "filter")
	filter.set_property("caps", caps)
	queue = Gst.ElementFactory.make("queue", "queue")
	sink = Gst.ElementFactory.make("nveglglessink", "video-sink")
	sink.set_property("window-x", 0)
	sink.set_property("window-y", 0)
	sink.set_property("window-width", 1280)
	sink.set_property("window-height", 720)
	# Create a bin and add elements
	bin = Gst.Bin.new("my-bin")
	bin.add(source)
	bin.add(depay_pre_decode)
	bin.add(parse)
	bin.add(decoder)
	if not depay_pre_decode.link(parse):
		print('Depay_pre_decode could not be linked to parse. Exiting.')
		sys.exit(-1)
	if not parse.link(decoder):
		print('Parse could not be linked to decoder. Exiting.')
		sys.exit(-1)
	# Add a ghost pad to the bin
	bin.add_pad(Gst.GhostPad.new("src", decoder.get_static_pad("src")))
	pipeline.add(bin)
	pipeline.add(convert)
	pipeline.add(filter)
	pipeline.add(queue)
	pipeline.add(sink)
	# Link bin to the rest of the pipeline
	if not bin.link(convert):
		print('Bin could not be linked to convert. Exiting.')
		sys.exit(-1)
	if not convert.link(filter):
		print('Convert could not be linked to filter. Exiting.')
		sys.exit(-1)
	if not filter.link(queue):
		print('Filter could not be linked to queue. Exiting.')
		sys.exit(-1)
	if not queue.link(sink):
		print('Queue could not be linked to sink. Exiting.')
		sys.exit(-1)
	bus = pipeline.get_bus()
	bus.add_signal_watch()
	bus.connect("message::error", on_error)
	# Mettre le pipeline en lecture
	ret = pipeline.set_state(Gst.State.PLAYING)
	if ret == Gst.StateChangeReturn.FAILURE:
		print("Unable to set the pipeline to the playing state.", flush=True)
		sys.exit(-1)
	# Attendre que le pipeline rencontre une erreur ou EOS
	print("Running...")
	main_loop = GObject.MainLoop()
	try:
		main_loop.run()
	except KeyboardInterrupt:
		pass
	finally:
		pipeline.set_state(Gst.State.NULL)
		main_loop.quit()
if __name__ == "__main__":
	main()
LOGS
graph-deepstream-deepstream-1 | 0:01:12.551655836 1 0x7f954c007400 WARN rtspmedia rtsp-media.c:3272:wait_preroll: failed to preroll pipeline
graph-deepstream-deepstream-1 | 0:01:12.551715935 1 0x7f954c007400 WARN rtspmedia rtsp-media.c:3652:gst_rtsp_media_prepare: failed to preroll pipeline
graph-deepstream-deepstream-1 | 0:01:12.552460774 1 0x7f954c007400 ERROR rtspclient rtsp-client.c:1077:find_media: client 0x211a130: can't prepare media
graph-deepstream-deepstream-1 | 0:01:12.552631713 1 0x7f954c007400 ERROR rtspclient rtsp-client.c:2963:handle_describe_request: client 0x211a130: no media
It appears that there is an issue with your rtsp source from the log. Could you share the rtsp source to us?
It doesn’t work with the sample either:
/opt/nvidia/deepstream/deepstream-6.3/sources/apps/sample_apps/deepstream-testsr/deepstream_test_sr_app.c
I am using an AXIS P1455-LE Network Camera.
Here is the log :
0:00:01.525553470 372039 0x556bba146f30 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.3/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1         3x368x640
1   OUTPUT kFLOAT conv2d_bbox     16x23x40
2   OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:01.580371701 372039 0x556bba146f30 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.3/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:01.582483048 372039 0x556bba146f30 INFO                 nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:dstestsr_pgie_config.yml sucessfully
Running...
In cb_newpad
Recording started..
Recording done.
** ERROR: <RunUserCallback:207>: No video stream found
Recording started..
Recording done.
Recording started..
Recording done.
Recording started..
Recording done.
Unfortunately, I can’t give you access to the stream.
However, I can carry out the insrtuctions you provide and send you the results.
Thank you very much.
First, you need to confirm if your rtsp source is a format that gstreamer can support. Please refer to RTSP and run the pipeline on the page.
