• Hardware Platform (Jetson / GPU) Jetson Xavier NX • DeepStream Version:6.3 • JetPack Version (valid for Jetson only):5.1.3
When the gstreamer pipeline is running and suddenly the RTSP stream retrieval fails, the RTSPSRC plugin will retry the retrieval of the stream, which may cause the stream exported by my pipeline to lag in some players. How can I solve this problem?
The lag time is not very uniform, sometimes not exceeding 5 seconds, and sometimes it can be several tens of seconds. This is the screen I recorded, and on the right is the streaming video. I need to tell you a few points:
The above player may experience lag when watching streaming videos, but when I use VLC to watch streaming videos, it does not experience such lag;
2.The rtspsrc attribute set is
If there are still issues with this pipeline, then the problem is related to the rtspsrc plugin of Gstreamer. You can file a topic to the Gstreamer Forum to ask how to resolve this.
