• Hardware Platform (Jetson / GPU) Jetson Xavier NX
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1.1
• TensorRT Version
• Issue Type( questions, new requirements, bugs) Questions
I have a pipeline with a rtspsrc bin, bunch of video processing components including nvstreammux, and some other components for rtsp streamming.
Our task requires precision in timing and thus want to minimize the latency of the pipeline. A few (1-2) seconds are fine but we realize the latency keeps building up after letting the pipeline run for about 20 hours.
We understand there are unavoidable latency that we have to bear with given the number of video processing tasks and the processing power of the device, yet I believe there would be some properties or plugins that we can still use to minimize the latency.
Lowering the output resolution and/or including the interval in nvinfer also helps, but is there any way that we can force-set the maximum latency between the input and output stream? We wonder if any deepstream plugin has such property.
