**• Hardware Platform (Jetson / GPU)**Jetson
• DeepStream Version5.0
• TensorRT Version
gst-launch-1.0 rtspsrc location=rtsp://192.168.3.199/h264/ch1/main/av_stream ! rtph264depay ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 width=1920 height=1080 ! nvinfer config-file-path=pgie_config.txt ! nvvideoconvert ! nvdsosd ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! flvmux ! rtmpsink location=rtmp://192.168.3.200:1935/live/test sync=false
infer plugin interval = 9 cost 500ms, fps = 20
Then I want rtmpsink output is frame per 50ms,I can add plug-ins to keep the most recent multiframes to smooth out the interval between outputs per frame,But I can not find good way to do this
