I have 2 graphic card attached. one GTX1080TI and RTX2080 SUPER. I’m having difficulty running the RTX2080.
I’m on
root@ubuntu:/home/user# uname -r
6.2.0-20-generic
root@ubuntu:/home/user# cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=23.04
DISTRIB_CODENAME=lunar
DISTRIB_DESCRIPTION="Ubuntu 23.04"
root@ubuntu:/home/user# ubuntu-drivers devices
== /sys/devices/pci0000:00/0000:00:1c.0/0000:01:00.0 ==
modalias : pci:v000010DEd00001E81sv000019DAsd00006500bc03sc00i00
vendor : NVIDIA Corporation
model : TU104 [GeForce RTX 2080 SUPER]
manual_install: True
driver : nvidia-driver-525-open - distro non-free
driver : nvidia-driver-515-open - distro non-free
driver : xserver-xorg-video-nouveau - distro free builtin
== /sys/devices/pci0000:00/0000:00:1c.1/0000:02:00.0 ==
modalias : pci:v000010DEd00001B06sv00001458sd0000376Bbc03sc00i00
model : GP102 [GeForce GTX 1080 Ti]
driver : nvidia-driver-470-server - distro non-free
driver : nvidia-driver-450-server - distro non-free
driver : nvidia-driver-470 - distro non-free
driver : nvidia-driver-530 - third-party non-free
driver : nvidia-driver-510 - distro non-free recommended
driver : nvidia-driver-515-server - distro non-free
driver : nvidia-driver-515 - third-party non-free
driver : nvidia-driver-525 - third-party non-free
driver : nvidia-driver-525-server - distro non-free
driver : nvidia-driver-520 - third-party non-free
driver : nvidia-driver-390 - distro non-free
root@ubuntu:/home/user# dpkg -l | grep nvidia- | grep ii
ii libnvidia-cfg1-530:amd64 530.30.02-0ubuntu1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-530 530.30.02-0ubuntu1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-530:amd64 530.30.02-0ubuntu1 amd64 NVIDIA libcompute package
ii libnvidia-compute-530:i386 530.30.02-0ubuntu1 i386 NVIDIA libcompute package
ii libnvidia-decode-530:amd64 530.30.02-0ubuntu1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-530:i386 530.30.02-0ubuntu1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-530:amd64 530.30.02-0ubuntu1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-530:i386 530.30.02-0ubuntu1 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-530:amd64 530.30.02-0ubuntu1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-530:amd64 530.30.02-0ubuntu1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-530:i386 530.30.02-0ubuntu1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-530:amd64 530.30.02-0ubuntu1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-530:i386 530.30.02-0ubuntu1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii nvidia-compute-utils-530 530.30.02-0ubuntu1 amd64 NVIDIA compute utilities
ii nvidia-dkms-530 530.30.02-0ubuntu1 amd64 NVIDIA DKMS package
ii nvidia-driver-530 530.30.02-0ubuntu1 amd64 NVIDIA driver metapackage
ii nvidia-kernel-common-530 530.30.02-0ubuntu1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-530 530.30.02-0ubuntu1 amd64 NVIDIA kernel source package
ii nvidia-modprobe 530.30.02-0ubuntu1 amd64 Load the NVIDIA kernel driver and create device files
ii nvidia-prime 0.8.17.1 all Tools to enable NVIDIA's Prime
ii nvidia-settings 530.30.02-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-530 530.30.02-0ubuntu1 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18.3 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-530 530.30.02-0ubuntu1 amd64 NVIDIA binary Xorg driver
In dmesg:
[ 3.966226] nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
[ 3.966234] ucsi_ccg 0-0008: i2c_transfer failed -110
[ 3.966237] ucsi_ccg 0-0008: ucsi_ccg_init failed - -110
[ 3.966240] ucsi_ccg: probe of 0-0008 failed with error -110
[ 4.114160] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x24:0x72:1428)
[ 4.114392] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 4.114823] [drm:nv_drm_load [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NvKmsKapiDevice
[ 4.114963] [drm:nv_drm_probe_devices [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to register device
[ 4.115081] [drm] [nvidia-drm] [GPU ID 0x00000200] Loading driver
[ 4.799629] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x24:0x72:1428)
[ 4.799885] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 4.808257] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:02:00.0 on minor 1
[ 4.836618] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 4.898852] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x24:0x72:1428)
[ 4.899211] nvidia-uvm: Loaded the UVM driver, major device number 235.
[ 4.899789] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 4.930901] loop25: detected capacity change from 0 to 8
[ 5.489306] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 5.492922] Bridge firewalling registered
[ 5.561802] Initializing XFRM netlink socket
[ 5.755265] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x24:0x72:1428)
[ 5.755519] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 5.802004] kauditd_printk_skb: 47 callbacks suppressed
[ 5.802007] audit: type=1400 audit(1684573797.608:58): apparmor="DENIED" operation="capable" class="cap" profile="/snap/snapd/19122/usr/lib/snapd/snap-confine" pid=1358 comm="snap-confine" capability=12 capname="net_admin"
[ 5.803068] audit: type=1400 audit(1684573797.608:59): apparmor="DENIED" operation="capable" class="cap" profile="/snap/snapd/19122/usr/lib/snapd/snap-confine" pid=1358 comm="snap-confine" capability=38 capname="perfmon"
[ 5.847903] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x24:0x72:1428)
[ 5.848107] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 5.956783] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x24:0x72:1428)
[ 5.957085] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 6.066959] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x24:0x72:1428)
[ 6.067205] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 6.201211] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x24:0x72:1428)
[ 6.201430] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 6.291465] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x24:0x72:1428)
[ 6.291631] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 91.711453] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x24:0x72:1428)
[ 91.711617] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 91.800459] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x24:0x72:1428)
[ 91.800636] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 785.734350] [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000200] Failed to grab modeset ownership
[ 785.795952] nvidia-uvm: Unloaded the UVM driver.
[ 836.648292] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 836.679886] nvidia-uvm: Loaded the UVM driver, major device number 235.
[ 836.765615] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x24:0x72:1428)
[ 836.765779] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 836.853546] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x24:0x72:1428)
root@ubuntu:/home/user# nvidia-smi
Sat May 20 12:03:56 2023
| NVIDIA-SMI 530.30.02 Driver Version: 530.30.02 CUDA Version: 12.1 |
| | | MIG M. |
| 0 NVIDIA GeForce GTX 1080 Ti On | 00000000:02:00.0 Off | N/A |
| 7% 36C P8 10W / 250W| 6MiB / 11264MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1375 G /usr/lib/xorg/Xorg 4MiB |
