I have a rtx 3090 ventus 3x OC and I am unable to use the full power of the card. My cpu is a Ryzen 5900x, my motherboard is the ASUS TUF Gaming X570-Plus (Wi-Fi), and I have 64GB G.Skill 3200mhz ddr4 ram. The entire system is watercooled and the gpu temps never hit above 40C and the gpu vram temps stay around 50C. The issue I am facing is that no matter what type of workload I try to use, the gpu never goes above 320 watts even though its rated for 350. The PSU I am using is rated for 1000 watts so that should not be the issue. Also when I run nvidia-smi -q the reason for throttling is listed as “SW Power Cap”. I have tried setting the max power draw to 350 but that doesn’t affect the issue. The issue persists on both the official and open source drivers. I have tried multiple different benchmarks/games and the gpu consistently stays below 320 watts. It can’t be a temperature issue as the gpu is watercooled and the temps on the core and the vram never gets above 50C. I have no clue what could be causing this.
Related topics
Topic | Replies | Views | Activity | |
RTX 3090 Not utilizing full power, limited by "SW Power Cap" under full load | 2 | 1177 | December 10, 2023 | |
Is my RTX 3090 not receiving enough power? | 5 | 5539 | November 29, 2023 | |
3090 power throttles around 300w | 9 | 854 | April 18, 2024 | |
RTX 3090 throttles down underload temps looks fine | 3 | 978 | January 10, 2022 | |
Limited clock for the new RTX3090Ti + Ubuntu 20.04 | 15 | 3181 | December 5, 2022 | |
Nvidia RTX 3090 SW Thermal Slowdown always active | 6 | 4488 | June 15, 2023 | |
Maximum power draw 3090 | 3 | 11144 | February 23, 2021 | |
Idle GPU power draw over 100% (ubuntu/RTX3090) | 0 | 495 | December 20, 2022 | |
RTX 3060 Laptop can't use more than 80W, nvidia-powerd not found | 3 | 3036 | February 5, 2024 | |
[Lenovo Legion 5 RTX 3060, 460.x, 470.x, 495.x] Power draw stuck at 80W, Windows does 130W | 3 | 6032 | November 2, 2023 |
