I have been dealing with this issue since March thinking it was something on my system.
It is now clear this is an Nvidia driver issue and has been for a while.
Summary
On an RTX 4090 under Linux, exercising NVENC silently hard-resets the entire host — instant
power-cycle-like reset, no kernel panic, no oops, no Xid, no MCE, nothing in pstore. The GPU is cold
(46 °C) and drawing only ~92 W of its 450 W budget when it happens.
The fault is codec-dependent, which we think is the most useful clue:
| Encoder | Result | Timing |
av1_nvenc |
Reproducible crash | ~15 s into the encode, steady state |
h264_nvenc |
Intermittent crash (2 of 10 runs) | ~11–40 s after the encode ends, at idle, during/after the clock ramp-down |
hevc_nvenc |
No crash observed (2 of 2 runs) | — (incl. a deliberate 120 s post-encode idle watch) |
This is not an application bug: it reproduces with bare ffmpeg, no VR runtime, no compositor
involvement beyond the normal desktop, and no other GPU load.
Minimal reproducer
ffmpeg -hide_banner -y -f lavfi -i testsrc2=duration=300:size=1280x720:rate=90 \
-c:v av1_nvenc -qp 18 out.mp4
Host resets silently ~15 seconds in. No output is flushed; the file is truncated or absent.
Substituting h264_nvenc reproduces intermittently and with different timing (dies after the
encode completes, during the return to idle). hevc_nvenc has not reproduced.
Telemetry at the moment of death
Sampled at 1 Hz with nvidia-smi, sync-flushed each sample so the log survives the reset
(av1_nvenc run, 2026-08-06):
time gpuC gpuW util% enc% memMiB pstate memclk smclk cpu_pkg
14:35:23.855 43 31.78 1 0 1167 P8 405 210 44.6 <- idle
14:35:24.983 45 54.67 9 45 1645 P2 10251 2790 45.4 <- encoder engages
14:35:26.102 45 91.58 9 50 1645 P2 10251 2790 45.6
... steady 91-92 W, 45-46 C, enc 50% for 15 seconds ...
14:35:38.583 46 91.93 9 50 1645 P2 10251 2790 58.9
14:35:39.699 46 92.12 9 50 1645 P2 10251 2790 59.4 <- last sample
<- SILENT RESET
Nothing anomalous precedes it. Temperature, power, clocks and encoder utilisation are all flat and
unremarkable. Note GPU utilisation is only 9 % — the graphics engine is nearly idle; it is the encoder engine that is active.
Full 1 Hz captures available if reqeusted.
Failure signature
- Instant whole-host reset. Not a hang, not a GPU fallback, not a driver restart.
/sys/fs/pstore/is empty every time, withkernel.panic_on_oops=1and
kernel.softlockup_panic=1armed. They have never once tripped.- No Xid, no NVRM error, no MCE, no PCIe AER, no oops in
journalctl -kfor the crashed boot. - The systemd journal simply stops mid-stream; journald reports the file “corrupted or uncleanly shut down” on the next boot.
- No core dump for any process.
The kernel never gets a chance to react, which suggests the failure is below the kernel’s handler
level.
Environment
| GPU | NVIDIA GeForce RTX 4090 |
| CPU | AMD Ryzen 9 7950X |
| RAM | 64 GiB DDR5, JEDEC 4800 MT/s, 1.1 V — EXPO/XMP disabled (no memory overclock) |
| OS | Fedora 44 |
| Kernel | 7.0.9-205.fc44.x86_64 |
| Driver | 610.43.03, open kernel module (RPM Fusion akmod-nvidia) (Also 580 and 595) |
| Desktop | KDE Plasma 6.6.5, Wayland |
| ffmpeg | 8.1.1 (Fedora) |
What we have already ruled out
Testing has been extensive (see “History” below). The following are excluded:
- Driver branch — reproduces on 580.159.03, 595.71.05, and 610.43.03.
- Kernel module variant — reproduces on both the open and proprietary builds of 595.71.05.
- Distro / kernel — reproduces on Fedora 43 (kernels 6.18.10, 7.0.8) and Fedora 44 (7.0.9).
- Thermals — dies at 45–46 °C GPU.
- Power capacity — dies at ~92 W on a card rated to 450 W. Gross PSU capacity is not
plausibly the constraint. - Graphics load — GPU utilisation is 9 % at the time of death; only the encoder is busy.
- Memory overclock — EXPO is off; RAM runs at JEDEC 4800.
- Application software — reproduces with bare
ffmpegand nothing else running.
Partial mitigation (a clue, not a fix)
Locking the VRAM clock low with nvidia-smi -pm 1 && nvidia-smi -lmc 5001 measurably reduces crash frequency but does not eliminate it — we have crashed with the lock held. Crashes have been observed at the full P0 VRAM clock (10501 MHz), at the P2 clock (10251 MHz) and at the P8 idle floor (405 MHz), so clock state alone does not explain it either.
Regression
This hardware ran sustained NVENC workloads (VR streaming, many hours) without incident in
January–February 2026, on a driver branch predating 580. The machine was then not used for that workload until mid-May 2026, at which point the fault was present and has persisted through every driver, kernel and distro combination since. We were unable to recover the exact January driver version to bisect — it is no longer packaged for this distro release and will not build against
current kernels.
History
The fault was originally investigated as a bug in WiVRn (an OpenXR streaming server) at
https://github.com/WiVRn/WiVRn/issues/981, because that was the workload exercising NVENC. It has since been shown to reproduce with no VR software present at all, which is why it is being
reported here. A second contributor with an RTX 4090 has reproduced a matching whole-system crash independently.
What would help
- Confirmation of whether the codec asymmetry (av1 reproduces readily, h264 intermittently,
hevc not at all) points at a specific engine or firmware path. - Guidance on capturing anything at all from a failure this abrupt — every standard mechanism
(pstore, panic-on-oops, Xid, MCE) has produced nothing across dozens of occurrences. - Whether GSP firmware is implicated — we have not been able to test
NVreg_EnableGpuFirmware=0
because the open module requires GSP.
Correction to my original post — hevc_nvenc is not immune.
In the original report I listed hevc_nvenc as “no crash observed (2 of 2 runs)” and presented the
codec asymmetry as the key clue. That was based on short encodes: with the default input pacing,
ffmpeg encodes the 300-second test clip in about 25 seconds of wall time, so those runs only
exercised the encoder briefly.
I have since re-run hevc_nvenc as a sustained encode, pacing the input at native frame rate
(-re) so the encoder runs continuously, at settings closer to a real VR streaming workload
(1920x960, 90 fps):
ffmpeg -hide_banner -y -re -f lavfi -i testsrc2=duration=300:size=1920x960:rate=90 \
-c:v hevc_nvenc -qp 18 out.mp4
It crashed the host after 3 minutes 41 seconds of continuous encoding — same signature as
before: instant silent reset, empty pstore, no Xid, no MCE, no oops, journal terminating mid-line.
State at the last 1 Hz sample before the reset:
53 C · 76 W · GPU util 3% · encoder util 8-11% · 2160 MiB · P2 · mem 10251 MHz · SM 2565 MHz
CPU package 46 C
Worth noting the encoder duty cycle was only ~8-11% here — real-time pacing leaves the encoder
idle between frames, a much lighter load than the ~50% of the earlier burst runs. It still failed.
Revised interpretation: the codec ordering reflects time-to-failure, not immunity. Ranked by
how quickly each reproduces:
| Encoder | Time to host reset |
av1_nvenc |
~15 s, during the encode |
h264_nvenc |
after a ~25 s encode, during/after the return to idle (2 of 10 runs) |
hevc_nvenc |
~3 min 41 s of sustained encoding |
So all three NVENC codecs reproduce it; they differ in how long they take. Duration of encoder
activity appears to matter at least as much as which codec is in use.
The av1_nvenc reproducer in the original post is unaffected and remains the fastest way to
trigger it (~15 seconds, one command, no other software involved).
Apologies for the initial framing — I had over-read a difference that turned out to be an artifact
of how long each test ran.
