Hello, please tell me in which official documentation I can find out the base clock frequency of the RTX A6000. Different sources mention the value 1410 or 1455 MHz. Which value is correct?
Hi, why do you beed to know the exact frequencies, which we don’t publish widely?
You can actually monitor your GPUs clocks while running, using the nvidia-smi tool (comes with every driver install), in details, using the dmon feature… read about the syntax in the docu, nvidia-smi -h
Hi, I need to prove to the Customer the manufacturer’s declared value of the base clock frequency of A6000 in order to fulfill the requirements of the technical specification.
For example, for the A100 in the document “NVIDIA A100 80GB PCIe GPU Product Brief” (https://www.nvidia.com/content/dam/en-zz/Solutions/Data-Center/a100/pdf/PB-10577-001_v02.pdf), the manufacturer specifies the following values:
GPU clocks Base: 1065 MHz, Boost: 1410 MHz.
I require similar confirmation for the A6000.
