I’ve T600 Laptop GPU which report maximum graphics clock 2100 MHz. I have an issue that this GPU can run only on 1440 MHz or 770 MHz and never reach value higher than 1440. GPU temperature with low loaded CPU 65-70 C. Could you please help me to run GPU on specified 2100 MHz clock?
For Turing and newer, Max Clocks displayed by nvidia-smi is more or less just a theoretical value. Always 2100 for Turing/Ampere, 3105 for Ada. You won’t be able to reach those. For a T600, the boost clocks are about 1400MHz.
