Run 2 NVIDIA cards at the same time (GTX 770 and Quadro P600)
Build:
Intel i7-4930K
ASUS X79 Deluxe (4 PCI-e)
Corsair - 32 GB DDR3
OS Drive - WD Black Sn850X (2 TB)
Video Card - Base - PNY GeForce GTX 770 (main via DP, sides with DVI)
Win 10 x64
Situation:
I have a GeForce GTX 770 that runs my multiple monitor setup perfectly. (3 monitors, Tie fighter config)
Recently I’ve been working with ArcGIS Pro (~v3.5), and the GeForce GTX 770, while it meets memory requirements, does not meet the Compute Capability for doing AI/Deep learning Geoprocessing Tools.
I purchased an in spec Video Card (Quadro P600) that meets ArcGIS Pro Compute Capacity to do AI/Deep Learning Tasks.
I would like to run both video cards, the GTX 770 for my monitors, and the Quadro P600 in place for ArcGIS (no video out on the Quadro), FYI, one can select the GPU # identifier (what is shown in Windows 10 Task Manager) to do the/a Geoprocessing Tool.
Process:
I’ve tried different configurations with the 770 and the P600 in different slots. None have worked.
Basics, I can’t get the P600 to post alone in the rig, in any slot. I can get the 770 to post into the OS with the P600 in a different slot.
Once posted with the 770, and into the OS (Win 10 x64) it takes about ~10 min for the system to black screen and reboot, at that point, both drivers for the 770 and P600 are “corrupt” (both are flagged under device manager), and at this time, there is no multiple monitor support for the 770. (Only one monitor supported)
I can reinstall the drivers for the 770, but it takes two reboots.
In this time, the P600 drops from being identified under Device Manager to a default “Microsoft Video Device”
Only a reconfiguration of cards/slots can start this failure loop over again.
My Thoughts:
Think this is because the 770 (~v475) and the P600 (~v573) support different drivers?
Or the P600 is kinda f’ed, and that is why it isn’t pushing through post, and has issues in w10 x64.
Current Next Steps:
Have a old CPU/MB setup that I use as a DBan box, will try the P600 in that next to see if I can get a post. If it posts, then I’m going with an issue with diff drivers or an issue with my MB supporting 2 video cards?
Past that, I’m a bit lost.
Conclusion:
Would appreciate any feedback or processes to get my ideal situation working.
Update - 20250707 2332
Have tried the P600 in 3 different builds, the other 2 were AMD 939, but I would think the Quadro would at least POST? Regardless, the P600 did not POST under any config.
Thinking I got a bad video card (Quadro P600)?
Does the P600 post as the only card fitted, with a 5XX driver?
I ask, as the latest driver that supports the GTX770, 475.14, shows no support for Pascal devices.
No, I can’t get the P600 (by itself) to post in the main system, and even tried the P600 in 2 other systems, nothing comes up on screen. I think the P600 is a bad card.
OK, that’s not a good sign.
