Run_dev.sh issue
When I used the following command on Jetson AGX Orin Devkit installed JetPack 6.2 including SDK Components, I got the error.
Could you please help me to pass through this process to run_dev.sh?
cd ${ISAAC_ROS_WS}/src/isaac_ros_common && ./scripts/run_dev.sh -d ${ISAAC_ROS_WS} nvidia@nvidia-desktop:~/workspaces/isaac_ros-dev/src/isaac_ros_common$ cd ${ISAAC_ROS_WS}/src/isaac_ros_common && ./scripts/run_dev.sh -d ${ISAAC_ROS_WS} Launching Isaac ROS Dev container with image key aarch64.ros2_humble.realsense: /home/nvidia/workspaces/isaac_ros-dev/ Building aarch64.ros2_humble.realsense base as image: isaac_ros_dev-aarch64 Building layered image for key aarch64.ros2_humble.realsense as isaac_ros_dev-aarch64 Using configured docker search paths: /home/nvidia/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker Checking if base image nvcr.io/nvidia/isaac/ros:aarch64-ros2_humble-realsense_73bdc4f3da30eb244b5da1b52c951ca0 exists on remote registry Checking if base image nvcr.io/nvidia/isaac/ros:aarch64-ros2_humble_d33953d7abe50ce895998252e51aca25 exists on remote registry Found pre-built base image: nvcr.io/nvidia/isaac/ros:aarch64-ros2_humble_d33953d7abe50ce895998252e51aca25 aarch64-ros2_humble_d33953d7abe50ce895998252e51aca25: Pulling from nvidia/isaac/ros Digest: sha256:b7da1fbf1280238a2c1b098c4eb658177eed171ee66fdf7842f8dd3693e34d9e Status: Image is up to date for nvcr.io/nvidia/isaac/ros:aarch64-ros2_humble_d33953d7abe50ce895998252e51aca25 nvcr.io/nvidia/isaac/ros:aarch64-ros2_humble_d33953d7abe50ce895998252e51aca25 Finished pulling pre-built base image: nvcr.io/nvidia/isaac/ros:aarch64-ros2_humble_d33953d7abe50ce895998252e51aca25 Resolved the following 1 Dockerfiles for target image: aarch64.ros2_humble.realsense /home/nvidia/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker/Dockerfile.realsense Building /home/nvidia/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker/Dockerfile.realsense as image: isaac_ros_dev-aarch64 with base: nvcr.io/nvidia/isaac/ros:aarch64-ros2_humble_d33953d7abe50ce895998252e51aca25 [+] Building 0.1s (13/13) FINISHED docker:default => [internal] load build definition from Dockerfile.realsense 0.0s => => transferring dockerfile: 2.42kB 0.0s => [internal] load metadata for nvcr.io/nvidia/isaac/ros:aarch64-ros2_humble_d33953d7abe50ce895998252e51aca25 0.0s => [internal] load .dockerignore 0.0s => => transferring context: 2B 0.0s => [stage-0 1/8] FROM nvcr.io/nvidia/isaac/ros:aarch64-ros2_humble_d33953d7abe50ce895998252e51aca25 0.0s => [internal] load build context 0.0s => => transferring context: 280B 0.0s => CACHED [stage-0 2/8] COPY scripts/build-librealsense.sh /opt/realsense/build-librealsense.sh 0.0s => CACHED [stage-0 3/8] COPY scripts/install-realsense-dependencies.sh /opt/realsense/install-realsense-dependencies.sh 0.0s => CACHED [stage-0 4/8] RUN chmod +x /opt/realsense/install-realsense-dependencies.sh && /opt/realsense/install-realsense-dependencies.sh; chmod +x / 0.0s => CACHED [stage-0 5/8] RUN mkdir -p /opt/realsense/ 0.0s => CACHED [stage-0 6/8] COPY scripts/hotplug-realsense.sh /opt/realsense/hotplug-realsense.sh 0.0s => CACHED [stage-0 7/8] COPY udev_rules/99-realsense-libusb-custom.rules /etc/udev/rules.d/99-realsense-libusb-custom.rules 0.0s => CACHED [stage-0 8/8] RUN --mount=type=cache,target=/var/cache/apt mkdir -p /opt/ros/humble/src && cd /opt/ros/humble/src && git clone https://gith 0.0s => exporting to image 0.0s => => exporting layers 0.0s => => writing image sha256:b50b6fd2eaf2ecb22f641b6aa60f31556b9dedd14d0adc15e103b53fb4f725bc 0.0s => => naming to Docker Hub Container Image Library | App Containerization 0.0s Running isaac_ros_dev-aarch64-container
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: could not apply required modification to OCI specification: error modifying OCI spec: failed to inject CDI devices: unresolvable CDI devices nvidia.com/gpu=all: unknown
Run ‘docker run --help’ for more information
https://www.jetson-ai-lab.com/tips_ssd-docker.html#__tabbed_1_2
thanks
Hi @A_Y
Thank you for your post.
Have you checked if your Jetson is properly installed? Please check our documentation: Compute Setup — isaac_ros_docs documentation
Best,
Raffaello
To @Raffaello
Thank you for the reply.
But, I have already checked it and the issue still remains.
The root cause of this issue was not to follow " Jetson Setup for VPI"
When I checked the following content, I just solved this issue out.
