Run VLLM in Spark
FROM nvidia/cuda:13.0.2-cudnn-devel-ubuntu24.04
# Install essentials
RUN apt-get update && apt-get install -y \
python3.12 python3.12-venv python3-pip git wget patch \\
&& rm -rf /var/lib/apt/lists/\*
# Set working directory
WORKDIR /app
# Create virtual env
RUN python3.12 -m venv /opt/venv
ENV PATH=“/opt/venv/bin:$PATH”
# Upgrade pip
RUN pip install --upgrade pip
# Install PyTorch + CUDA
RUN pip install torch torchvision torchaudio --index-url https://download.pytorch.org/whl/cu130
# Install pre-release deps
RUN pip install xgrammar triton
RUN pip install -U --pre flashinfer-python --index-url Index of nightly --no-deps
RUN pip install flashinfer-python
RUN pip install -U --pre flashinfer-cubin --index-url Index of nightly
# JIT cache package (replace cu129 with your CUDA version: cu128, cu129, or cu130)
RUN pip install -U --pre flashinfer-jit-cache --index-url Index of cu130
# Clone vLLM
RUN git clone GitHub - vllm-project/vllm: A high-throughput and memory-efficient inference and serving engine for LLMs
WORKDIR /app/vllm
RUN git fetch origin pull/26844/head:pr-26844
RUN git -c user.name=“CI Bot” -c user.email="ci@example.com" merge --no-ff --no-edit pr-26844
RUN python3 use_existing_torch.py
RUN sed -i “/flashinfer/d” requirements/cuda.txt
RUN pip install -r requirements/build.txt
cmake \\
build-essential \\
ninja-build \\
# Set essential environment variables
ENV TORCH_CUDA_ARCH_LIST=12.1a
ENV TRITON_PTXAS_PATH=/usr/local/cuda/bin/ptxas
ENV TIKTOKEN_ENCODINGS_BASE=/app/tiktoken_encodings
# Install vLLM with local build
RUN pip install --no-build-isolation -e . -v --pre
RUN pip install --no-build-isolation -e .[audio] -v --pre
# Download tiktoken encodings
WORKDIR /app
RUN mkdir -p tiktoken_encodings && \
wget -O tiktoken_encodings/o200k_base.tiktoken "https://openaipublic.blob.core.windows.net/encodings/o200k_base.tiktoken" && \\
wget -O tiktoken_encodings/cl100k_base.tiktoken "https://openaipublic.blob.core.windows.net/encodings/cl100k_base.tiktoken"
WORKDIR /app/vllm
# Expose port
EXPOSE 8888
ENTRYPOINT
This builds successfully for me, posting here if anyone should need it. 11/14 flashinfer nightly included.
