Run YOLOv5 on JETSON NANO with CSI-camera
I tried many ways, but still can’t use CSI camera to run YOLOv5 to detect real-time.
Please help me!
This is my code:
detect.py (15.2 KB)
It seems the camera interface is implemented in the LoadStreams module.
We will need the source as well to check the issue.
from utils.dataloaders import IMG_FORMATS, VID_FORMATS, LoadImages, LoadStreams
    # Dataloader
    if webcam:
        view_img = check_imshow()
        cudnn.benchmark = True  # set True to speed up constant image size inference
        dataset = LoadStreams(source, img_size=imgsz, stride=stride, auto=pt)
        bs = len(dataset)  # batch_size
    else:
Are you reading the camera with OpenCV?
If yes, it’s recommended to check the below sample first to see if it helps.
dataloaders.py (45.6 KB)
Thanks for your answer.
But I don’t know where to put that code.
Have you managed to get issue resolved or still need the support? Thanks
