Running a repo using jax on Jetson Orin AGX 64GB GPU
I am trying to run this repo on my Jeton Orin AGX 64GB developer kit: GitHub - vincekurtz/hydrax: Sampling-based model predictive control on GPU with JAX/MJX. It runs MuJoCo MPC on the GPU using Jax. However, when trying to run this I get a load of errors, listed below. The failed import of warp is not an issue, since after installing this I get the same error, and the repo works on other x86_64 based devices with the failed import. After a lot of bug-testing, I landed on trying to build Jax wheels locally, but when trying to build jax==0.5.0 in the conda environment I created for this repo, I get data type errors where it expects a uint8 but receives a svuint8. I don’t know how to continue from here to get jax to work with cuda support. I also included some diagnostics below. I am running Jetpack version 6.2.1 and Ubuntu 22.04, since I need ros2 Humble.
Failed to import warp: No module named 'warp'
Failed to import mujoco_warp: No module named 'warp'
E1120 11:39:58.116684 14373 cuda_executor.cc:1784] Nvml call failed with 3(Not Supported). Assuming PCIe gen 3 x16 bandwidth.
W1120 11:39:58.116796 14373 cuda_executor.cc:1802] GPU interconnect information not available: INTERNAL: NVML library doesn't have required functions.
E1120 11:39:58.121420 14323 cuda_executor.cc:1784] Nvml call failed with 3(Not Supported). Assuming PCIe gen 3 x16 bandwidth.
W1120 11:39:58.121453 14323 cuda_executor.cc:1802] GPU interconnect information not available: INTERNAL: NVML library doesn't have required functions.
E1120 11:39:58.131061 14323 cuda_dnn.cc:456] Loaded runtime CuDNN library: 9.3.0 but source was compiled with: 9.8.0. CuDNN library needs to have matching major version and equal or higher minor version. If using a binary install, upgrade your CuDNN library. If building from sources, make sure the library loaded at runtime is compatible with the version specified during compile configuration.
E1120 11:39:58.132785 14323 cuda_dnn.cc:456] Loaded runtime CuDNN library: 9.3.0 but source was compiled with: 9.8.0. CuDNN library needs to have matching major version and equal or higher minor version. If using a binary install, upgrade your CuDNN library. If building from sources, make sure the library loaded at runtime is compatible with the version specified during compile configuration.
E1120 11:40:13.433815 14323 cuda_dnn.cc:456] Loaded runtime CuDNN library: 9.3.0 but source was compiled with: 9.8.0. CuDNN library needs to have matching major version and equal or higher minor version. If using a binary install, upgrade your CuDNN library. If building from sources, make sure the library loaded at runtime is compatible with the version specified during compile configuration.
E1120 11:40:13.449384 14323 cuda_dnn.cc:456] Loaded runtime CuDNN library: 9.3.0 but source was compiled with: 9.8.0. CuDNN library needs to have matching major version and equal or higher minor version. If using a binary install, upgrade your CuDNN library. If building from sources, make sure the library loaded at runtime is compatible with the version specified during compile configuration.
File "/home/jetson/hydrax/examples/cart_pole.py", line 14, in <module>
task = CartPole()
File "/home/jetson/hydrax/hydrax/tasks/cart_pole.py", line 18, in __init__
super().__init__(mj_model, trace_sites=["tip"])
File "/home/jetson/hydrax/hydrax/task_base.py", line 38, in __init__
self.model = mjx.put_model(mj_model)
File "/home/jetson/miniconda3/envs/hydrax/lib/python3.12/site-packages/mujoco/mjx/_src/io.py", line 513, in put_model
return _put_model_jax(m, device)
File "/home/jetson/miniconda3/envs/hydrax/lib/python3.12/site-packages/mujoco/mjx/_src/io.py", line 421, in _put_model_jax
return _strip_weak_type(model)
File "/home/jetson/miniconda3/envs/hydrax/lib/python3.12/site-packages/mujoco/mjx/_src/io.py", line 166, in _strip_weak_type
return jax.tree_util.tree_map(f, tree)
File "/home/jetson/miniconda3/envs/hydrax/lib/python3.12/site-packages/jax/_src/tree_util.py", line 361, in tree_map
return treedef.unflatten(f(*xs) for xs in zip(*all_leaves))
File "/home/jetson/miniconda3/envs/hydrax/lib/python3.12/site-packages/jax/_src/tree_util.py", line 361, in <genexpr>
File "/home/jetson/miniconda3/envs/hydrax/lib/python3.12/site-packages/mujoco/mjx/_src/io.py", line 163, in f
return leaf.astype(jax.dtypes.canonicalize_dtype(leaf.dtype))
File "/home/jetson/miniconda3/envs/hydrax/lib/python3.12/site-packages/jax/_src/numpy/array_methods.py", line 125, in _astype
return lax_numpy.astype(self, dtype, copy=copy, device=device)
File "/home/jetson/miniconda3/envs/hydrax/lib/python3.12/site-packages/jax/_src/numpy/lax_numpy.py", line 5350, in astype
result = lax._convert_element_type(
File "/home/jetson/miniconda3/envs/hydrax/lib/python3.12/site-packages/jax/_src/lax/lax.py", line 1727, in _convert_element_type
return convert_element_type_p.bind(
File "/home/jetson/miniconda3/envs/hydrax/lib/python3.12/site-packages/jax/_src/core.py", line 632, in bind
return self._true_bind(*args, **params)
File "/home/jetson/miniconda3/envs/hydrax/lib/python3.12/site-packages/jax/_src/core.py", line 648, in _true_bind
return self.bind_with_trace(prev_trace, args, params)
File "/home/jetson/miniconda3/envs/hydrax/lib/python3.12/site-packages/jax/_src/lax/lax.py", line 5035, in _convert_element_type_bind_with_trace
operand = core.Primitive.bind_with_trace(convert_element_type_p, trace, args, params)
File "/home/jetson/miniconda3/envs/hydrax/lib/python3.12/site-packages/jax/_src/core.py", line 660, in bind_with_trace
return trace.process_primitive(self, args, params)
File "/home/jetson/miniconda3/envs/hydrax/lib/python3.12/site-packages/jax/_src/core.py", line 1189, in process_primitive
return primitive.impl(*args, **params)
File "/home/jetson/miniconda3/envs/hydrax/lib/python3.12/site-packages/jax/_src/dispatch.py", line 92, in apply_primitive
outs = fun(*args)
jax.errors.JaxRuntimeError: FAILED_PRECONDITION: DNN library initialization failed. Look at the errors above for more details.
For simplicity, JAX has removed its internal frames from the traceback of the following exception. Set JAX_TRACEBACK_FILTERING=off to include these.
(hydrax) jetson@ubuntu:~/hydrax$ pip list | grep nvidia
nvidia-cublas-cu12 12.9.1.4
nvidia-cuda-cupti-cu12 12.9.79
nvidia-cuda-nvcc-cu12 12.9.86
nvidia-cuda-nvrtc-cu12 12.9.86
nvidia-cuda-runtime-cu12 12.9.79
nvidia-cudnn-cu12 9.16.0.29
nvidia-cufft-cu12 11.4.1.4
nvidia-cusolver-cu12 11.7.5.82
nvidia-cusparse-cu12 12.5.10.65
nvidia-nccl-cu12 2.28.9
nvidia-nvjitlink-cu12 12.9.86
nvidia-nvshmem-cu12 3.4.5
(hydrax) jetson@ubuntu:~/hydrax$ conda list | grep cudnn
conda list | grep cudatoolkit
cudnn 9.10.2.21 h32c1c63_0 conda-forge
libcudnn 9.10.2.21 hd88968f_0 conda-forge
libcudnn-dev 9.10.2.21 h76cf850_0 conda-forge
nvidia-cudnn-cu12 9.16.0.29 pypi_0 pypi
(hydrax) jetson@ubuntu:~/hydrax$ cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX Open Kernel Module for aarch64 540.4.0 Release Build (buildbrain@mobile-u64-6354-d6000) Thu Sep 18 15:33:49 PDT 2025
GCC version: collect2: error: ld returned 1 exit status
(hydrax) jetson@ubuntu:~/hydrax$ nvcc --version
Copyright (c) 2005-2023 NVIDIA Corporation
Built on Fri_Sep__8_19:17:54_PDT_2023
Cuda compilation tools, release 12.3, V12.3.52
Build cuda_12.3.r12.3/compiler.33281558_0
(hydrax) jetson@ubuntu:~/hydrax$ nvidia-smi
Thu Nov 20 11:55:52 2025
| NVIDIA-SMI 540.4.0 Driver Version: 540.4.0 CUDA Version: 12.6 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 Orin (nvgpu) N/A | N/A N/A | N/A |
| N/A N/A N/A N/A / N/A | Not Supported | N/A N/A |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
(hydrax) jetson@ubuntu:~/hydrax$ cat /usr/include/cudnn_version.h | grep CUDNN_MAJOR -A 2
#define CUDNN_MAJOR 9
#define CUDNN_MINOR 3
#define CUDNN_PATCHLEVEL 0
#define CUDNN_VERSION (CUDNN_MAJOR * 10000 + CUDNN_MINOR * 100 + CUDNN_PATCHLEVEL)
/* cannot use constexpr here since this is a C-only file */
We don’t have experience about running the sample. Would see if other users can share experience.
Beside running this, you may also check
https://www.jetson-ai-lab.com/
See if there is similar AI applications you can try.
