After install JetPack 5.0.1 for Orin and test the mnistCUDNN got err info
orin@orin-desktop:/usr/src/cudnn_samples_v8/mnistCUDNN$ ./mnistCUDNN
Executing: mnistCUDNN
cudnnGetVersion() : 8401 , CUDNN_VERSION from cudnn.h : 8401 (8.4.1)
Host compiler version : GCC 9.4.0
ERROR: cuda failure (no CUDA-capable device is detected) in error_util.h:91
Aborting…
kayccc
2
Could you try with JetPack 5.0.2 GA release? Thanks
Thank your reply very much, and which is JetPack 5.0.2, now have 35.1 in the file /etc/apt/sources.list.d/nvidia-l4t-apt-source.list like this.
deb https://repo.download.nvidia.com/jetson/common r35.1 main
deb https://repo.download.nvidia.com/jetson/t234 r35.1 main
Have you fixed this issue?
Do the CUDA libraries not been installed by JetPack and caused this issue?
CUDA 11.4 was installed ready by JetPack, and should do I reinstall ubuntu20.04 on orin?
Flashed orin with SDK manager on a host pc fixed the err.
orin@ubuntu:/usr/src/cudnn_samples_v8/mnistCUDNN$ ./mnistCUDNN
There are 1 CUDA capable devices on your machine :
device 0 : sms 8 Capabilities 8.7, SmClock 1300.0 Mhz, MemSize (Mb) 30535, MemClock 1300.0 Mhz, Ecc=0, boardGroupID=0
Using device 0
Testing single precision
Loading binary file data/conv1.bin
Loading binary file data/conv1.bias.bin
Loading binary file data/conv2.bin
Loading binary file data/conv2.bias.bin
Loading binary file data/ip1.bin
Loading binary file data/ip1.bias.bin
Loading binary file data/ip2.bin
Loading binary file data/ip2.bias.bin
Loading image data/one_28x28.pgm
Performing forward propagation ...
Testing cudnnGetConvolutionForwardAlgorithm_v7 ...
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: -1.000000 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: -1.000000 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: -1.000000 time requiring 57600 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: -1.000000 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: -1.000000 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: -1.000000 time requiring 2057744 memory
^^^^ CUDNN_STATUS_NOT_SUPPORTED for Algo 6: -1.000000 time requiring 0 memory
^^^^ CUDNN_STATUS_NOT_SUPPORTED for Algo 3: -1.000000 time requiring 0 memory
Testing cudnnFindConvolutionForwardAlgorithm ...
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.062016 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.105792 time requiring 57600 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.172192 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.181600 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.362624 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.610880 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: -1.000000 time requiring 194632 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: -1.000000 time requiring 1433120 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: -1.000000 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: -1.000000 time requiring 128000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: -1.000000 time requiring 4656640 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.176416 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.226624 time requiring 194632 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.290368 time requiring 128000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.326272 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.580448 time requiring 4656640 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 1.054976 time requiring 1433120 memory
Resulting weights from Softmax:
0.0000000 0.9999399 0.0000000 0.0000000 0.0000561 0.0000000 0.0000012 0.0000017 0.0000010 0.0000000
Loading image data/three_28x28.pgm
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.056896 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.057888 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.103520 time requiring 57600 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.173792 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.200768 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.363712 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.168160 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.228096 time requiring 194632 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.282592 time requiring 128000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.319648 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.575072 time requiring 4656640 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 1.043904 time requiring 1433120 memory
0.0000000 0.0000000 0.0000000 0.9999288 0.0000000 0.0000711 0.0000000 0.0000000 0.0000000 0.0000000
Loading image data/five_28x28.pgm
0.0000000 0.0000008 0.0000000 0.0000002 0.0000000 0.9999820 0.0000154 0.0000000 0.0000012 0.0000006
Result of classification: 1 3 5
Test passed!
Testing half precision (math in single precision)
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: -1.000000 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.064032 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.067552 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.100224 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.222240 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.293952 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.358816 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: -1.000000 time requiring 2000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.203232 time requiring 2000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.256704 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.327744 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.356512 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.577312 time requiring 4656640 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 1.049984 time requiring 1433120 memory
0.0000001 1.0000000 0.0000001 0.0000000 0.0000563 0.0000001 0.0000012 0.0000017 0.0000010 0.0000001
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.057696 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.059200 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.081024 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.208384 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.220768 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.353952 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.189056 time requiring 2000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.254176 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.329664 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.356224 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.579552 time requiring 4656640 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 1.047040 time requiring 1433120 memory
0.0000000 0.0000000 0.0000000 1.0000000 0.0000000 0.0000714 0.0000000 0.0000000 0.0000000 0.0000000
0.0000000 0.0000008 0.0000000 0.0000002 0.0000000 1.0000000 0.0000154 0.0000000 0.0000012 0.0000006
Test passed!
Thanks for the update.
Good to know it works now.
