Jetpack 35.1 Orin : ERROR: cuda failure (no CUDA-capable device is detected)
After install Jetpack 35.1, and test cudnn_samples got err info below, please tell me how to do..
Comonds
sudo apt-get install libfreeimage3 libfreeimage-dev
cd /usr/src/cudnn_samples_v8/mnistCUDNN
sudo make
./mnistCUDNN
Complete logs:
orin@orin-desktop:/usr/src/cudnn_samples_v8/mnistCUDNN$ sudo make
CUDA_VERSION is 11040
Linking agains cublasLt = true
CUDA VERSION: 11040
TARGET ARCH: aarch64
HOST_ARCH: aarch64
TARGET OS: linux
SMS: 35 50 53 60 61 62 70 72 75 80 86
/usr/local/cuda/bin/nvcc -I/usr/local/cuda/include -I/usr/local/cuda/include -IFreeImage/include -ccbin g++ -m64 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_53,code=sm_53 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_62,code=sm_62 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_72,code=sm_72 -gencode arch=compute_75,code=sm_75 -gencode arch=compute_80,code=sm_80 -gencode arch=compute_86,code=sm_86 -gencode arch=compute_86,code=compute_86 -o fp16_dev.o -c fp16_dev.cu
nvcc warning : The ‘compute_35’, ‘compute_37’, ‘compute_50’, ‘sm_35’, ‘sm_37’ and ‘sm_50’ architectures are deprecated, and may be removed in a future release (Use -Wno-deprecated-gpu-targets to suppress warning).
g++ -I/usr/local/cuda/include -I/usr/local/cuda/include -IFreeImage/include -o fp16_emu.o -c fp16_emu.cpp
g++ -I/usr/local/cuda/include -I/usr/local/cuda/include -IFreeImage/include -o mnistCUDNN.o -c mnistCUDNN.cpp
/usr/local/cuda/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_53,code=sm_53 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_62,code=sm_62 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_72,code=sm_72 -gencode arch=compute_75,code=sm_75 -gencode arch=compute_80,code=sm_80 -gencode arch=compute_86,code=sm_86 -gencode arch=compute_86,code=compute_86 -o mnistCUDNN fp16_dev.o fp16_emu.o mnistCUDNN.o -I/usr/local/cuda/include -I/usr/local/cuda/include -IFreeImage/include -L/usr/local/cuda/lib64 -L/usr/local/cuda/lib64 -L/usr/local/cuda/lib64 -lcublasLt -LFreeImage/lib/linux/aarch64 -LFreeImage/lib/linux -lcudart -lcublas -lcudnn -lfreeimage -lstdc++ -lm
orin@orin-desktop:/usr/src/cudnn_samples_v8/mnistCUDNN$ ./mnistCUDNN
Executing: mnistCUDNN
cudnnGetVersion() : 8401 , CUDNN_VERSION from cudnn.h : 8401 (8.4.1)
Host compiler version : GCC 9.4.0
ERROR: cuda failure (no CUDA-capable device is detected) in error_util.h:91
Aborting…
By the way, i got others err..
use jtop cmd got no cuda info…
but nvcc -V can got cuda 11.4 info..
Python 3.8.10 (default, Jun 22 2022, 20:18:18)
[GCC 9.4.0] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
import pycuda.autoinit
File “<stdin>”, line 1, in <module>
File “/home/orin/.local/lib/python3.8/site-packages/pycuda/autoinit.py”, line 5, in
cuda.init()
pycuda._driver.RuntimeError: cuInit failed: no CUDA-capable device is detected
I will die to got result
Do you use the same package and OS from JetPack 5.0.2 GA?
We test the mnistCUDNN in our environment which is set up by JetPack 5.0.2 GA.
It can work correctly without issues.
$ ./mnistCUDNN
There are 1 CUDA capable devices on your machine :
device 0 : sms  8  Capabilities 8.7, SmClock 1300.0 Mhz, MemSize (Mb) 30535, MemClock 1300.0 Mhz, Ecc=0, boardGroupID=0
Using device 0
Testing single precision
Loading binary file data/conv1.bin
Loading binary file data/conv1.bias.bin
Loading binary file data/conv2.bin
Loading binary file data/conv2.bias.bin
Loading binary file data/ip1.bin
Loading binary file data/ip1.bias.bin
Loading binary file data/ip2.bin
Loading binary file data/ip2.bias.bin
Loading image data/one_28x28.pgm
Performing forward propagation ...
Testing cudnnGetConvolutionForwardAlgorithm_v7 ...
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: -1.000000 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: -1.000000 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: -1.000000 time requiring 57600 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: -1.000000 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: -1.000000 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: -1.000000 time requiring 2057744 memory
^^^^ CUDNN_STATUS_NOT_SUPPORTED for Algo 6: -1.000000 time requiring 0 memory
^^^^ CUDNN_STATUS_NOT_SUPPORTED for Algo 3: -1.000000 time requiring 0 memory
Testing cudnnFindConvolutionForwardAlgorithm ...
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.057088 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.061760 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.103616 time requiring 57600 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.170528 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 12.268832 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 31.228928 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: -1.000000 time requiring 194632 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: -1.000000 time requiring 1433120 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: -1.000000 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: -1.000000 time requiring 128000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: -1.000000 time requiring 4656640 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.165824 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.225536 time requiring 194632 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.290880 time requiring 128000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.322400 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.574944 time requiring 4656640 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 1.041920 time requiring 1433120 memory
Resulting weights from Softmax:
0.0000000 0.9999399 0.0000000 0.0000000 0.0000561 0.0000000 0.0000012 0.0000017 0.0000010 0.0000000
Loading image data/three_28x28.pgm
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.056864 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.060384 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.103520 time requiring 57600 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.169760 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.185408 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.369312 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.164864 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.220608 time requiring 194632 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.285696 time requiring 128000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.324960 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.571168 time requiring 4656640 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 1.053696 time requiring 1433120 memory
0.0000000 0.0000000 0.0000000 0.9999288 0.0000000 0.0000711 0.0000000 0.0000000 0.0000000 0.0000000
Loading image data/five_28x28.pgm
0.0000000 0.0000008 0.0000000 0.0000002 0.0000000 0.9999820 0.0000154 0.0000000 0.0000012 0.0000006
Result of classification: 1 3 5
Test passed!
Testing half precision (math in single precision)
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: -1.000000 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.063456 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.066656 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.137056 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.209600 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.284096 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.352352 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: -1.000000 time requiring 2000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.219168 time requiring 2000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.252512 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.319520 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.350720 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.579680 time requiring 4656640 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 1.050368 time requiring 1433120 memory
0.0000001 1.0000000 0.0000001 0.0000000 0.0000563 0.0000001 0.0000012 0.0000017 0.0000010 0.0000001
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.075872 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.078208 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.097152 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.161504 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.327232 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.352416 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.159968 time requiring 2000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.267520 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.326496 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.352576 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.566432 time requiring 4656640 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 1.050720 time requiring 1433120 memory
0.0000000 0.0000000 0.0000000 1.0000000 0.0000000 0.0000714 0.0000000 0.0000000 0.0000000 0.0000000
0.0000000 0.0000008 0.0000000 0.0000002 0.0000000 1.0000000 0.0000154 0.0000000 0.0000012 0.0000006
Test passed!
Thanks for your reply very much .
and do you know why cmd jtop got no cuda info like this :
Hi guys, I update jetpack with following way, and it tell me that only edit etc/apt/sources.list.d/nvidia-l4t-apt-source.list to point to the 35.1, so , My orin has JetPack 5.0/5.0.1 already.
https://docs.nvidia.com/jetson/jetpack/install-jetpack/index.html#upgrade-jetpack
Duplicate to topic 226045 which is fixed.
Please let us know if any further questions.
