Hi guys,
Spent 2 days trying to figure out how to launch an application which uses my Nvidia graphics card but not able to figure it out. I have installed the nvidia drivers and nvidia-prime and am able to run cuda samples successfully. But I am not sure how i can run say blender or freecad using the nvidia graphics.
Many of the tutorials mention prime-run but i cannot find that executable anywhere. I have followed the tutorial on prime render offload and installed the X server from the mentioned PPA. It mentions about glamoregl in the /var/log/Xorg.0.log which is not present in my case. Not sure how to install that as well.
I installed the latest nvidia drivers from the run file using command
sudo ./NVIDIA-Linux-x86_64-430.09.run --dkms --no-opengl-files
The following command gives output
__NV_PRIME_RENDER_OFFLOAD=1 __NV_PRIME_RENDER_OFFLOAD_PROVIDER=NVIDIA-G0 __GLX_VENDOR_LIBRARY_NAME=nvidia glxinfo | grep "OpenGL renderer"
OpenGL renderer string: Mesa DRI Intel(R) UHD Graphics 630 (Coffeelake 3x8 GT2)
Not sure what I am missing. Any help would be appreciated.
Setup details:
Lenovo Y540
Ubuntu 18.04
5.3.0-53-generic #47~18.04.1-Ubuntu
core i7 9750
Nvidia 1660Ti 6GB
also the sudo nvidia-settings gives the following output.
ERROR: Unable to load info from any available system
lsmod | grep nvidia
nvidia_drm 49152 1
nvidia_modeset 1105920 1 nvidia_drm
nvidia 18489344 4 nvidia_modeset
drm_kms_helper 180224 2 nvidia_drm,i915
drm 491520 18 drm_kms_helper,nvidia_drm,i915
ipmi_msghandler 102400 2 ipmi_devintf,nvidia
i2c_nvidia_gpu 16384 0
nvidia-smi
Sun May 24 19:26:44 2020
| NVIDIA-SMI 430.09 Driver Version: 430.09 CUDA Version: 10.1 |
| 0 GeForce GTX 166... Off | 00000000:01:00.0 Off | N/A |
| N/A 46C P8 3W / N/A | 1MiB / 5944MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
Attached output of sudo nvidia-bug-report.sh and renamed extension to .log
nvidia-bug-report.log (222.7 KB)
