Running chroma container via Singularity failed: There is no device supporting CUDA
I am trying to run the chroma container just for testing our new C4140 comes with 4 x V100. I have installed CUDA 10.0 on the host machine as normal. But when trying to run that it failed:
$ mpirun -n 4 chroma -i ./test.ini.xml -geom 1 1 1 4 -ptxdb ./qdpdb
There is no device supporting CUDA.
Primary job  terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
  Process name: [[58320,1],0]
  Exit code:    1
$ nvidia-smi
Thu Feb 28 14:38:45 2019
| NVIDIA-SMI 410.48                 Driver Version: 410.48                    |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  Tesla V100-SXM2...  Off  | 00000000:1A:00.0 Off |                    0 |
| N/A   37C    P0    55W / 300W |      0MiB / 16130MiB |      0%      Default |
|   1  Tesla V100-SXM2...  Off  | 00000000:1C:00.0 Off |                    0 |
| N/A   34C    P0    53W / 300W |      0MiB / 16130MiB |      0%      Default |
|   2  Tesla V100-SXM2...  Off  | 00000000:1D:00.0 Off |                    0 |
| N/A   33C    P0    54W / 300W |      0MiB / 16130MiB |      0%      Default |
|   3  Tesla V100-SXM2...  Off  | 00000000:1E:00.0 Off |                    0 |
| N/A   35C    P0    55W / 300W |      0MiB / 16130MiB |      4%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|  No running processes found                                                 |
$ nvcc --version
Copyright (c) 2005-2018 NVIDIA Corporation
Built on Sat_Aug_25_21:08:01_CDT_2018
Cuda compilation tools, release 10.0, V10.0.130
As you can see the container seems to be finding the devices OK. Any comment welcome.
Cheers,
Derrick
This is how I started the container:
I am using Singularity 3.0.2
$ singularity run --nv -B /opt/NVIDIA:/opt/NVIDIA chroma.simg
